Old 11-18-2002, 04:48 AM   #1
Low69CST
dipstick for 700R4's
I've got a 700 bolted up to my 400 sb. I bought a Lokar tranny dipstick, but the thing is made for a street rod is only about 6 inches long. The top the stick doesn't even make it over my headers, making it impossible to get to. What dipsticks have been used by u guys? Thought about just getting a 88-up truck dipstick, but i'd like one to match my kickdown and engine dipstick.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 11-18-2002, 07:28 AM   #2
Stepside
Gasser
I too bought the short one. I didn't like the idea of bolting the long one to the firewall. I just fabbed a simple bracket to "extend" the Lokar bracket. Mine now is more vertical behind the intake. Hope this helps.
:thud 70 sstep tubbed, Muncie, double hump, snowflake,
Stepside is offline   Reply With Quote
Old 11-18-2002, 11:59 AM   #3
Project1970
14.1 @ 96MPH
Project1970's Avatar
I just went to the local Chevy dealer and got one over the parts counter.
I don't think it honestly matters a whole lot what vehicle it's for, either...think about it, the transmission and engine are in the exact same place relative to each other in any vehicle that combo goes in.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 11-19-2002, 03:10 AM   #4
nate68
the place that built my trans gave me one, its prolly a standard gm item that you can get at the dealer
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 11-19-2002, 06:25 AM   #5
sam's 72
Go to the dealer and get one for a vette, like around a 90 model, it is long, and comes up behind and over the top of the passagenger side valve cover, but it is high enough to clear the valve cover if you have to pull the cover. The end will be plastic, the end also hinges up and turns into a handle, so you can pull on it. Works great and very very easy to get too
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
