Old 09-12-2008, 12:32 PM   #1
basketcase
basketcase's Avatar
Power Steering Line Trick
It seems like every one of these trucks I look at has different p/s lines. I ordered a new pressure line from NAPA and installed it and used one of 3 pumps I had; all with different reservoir return line tubes. None of these would point away from the frame enough to make me comfortable with the clearance. I think they were 6 cylinder or big truck pumps. So I swapped on a NOS '74 Corvette reservoir that I had that pointed straight dow. Using the hard line I had with the truck that went over the frame and curved down I connected a new piece of return hose and all was well in the clearance department.
Then I started worrying if the lines would vibrate loose on the box and turn enough to let the return line get into the pulley. I ordered a 3/8 double clamp from Summit (Earl's 167206ERL) that fit the o.d. of the lines perfectly. Once clamped on, the lines are triangulated and even if they come loose they can't move fore or aft.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 09-12-2008, 05:42 PM   #2
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: Power Steering Line Trick
Looks cool. I had a helluva time trying to find the proper lines for mine.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 09-12-2008, 10:21 PM   #3
72lb4x4
That looks great. I have the high pressure line and return stub sitting in the living room waiting for ambition to put them on. I've been wondering about the clamp.
After I put them on, I'll have to work on the new inner fender to get it installed, then the other, etc, etc...
I tried to get a rebuilt PS pump and res, but since my truck is a mix and match thing, I wound up with a bare pump and cleaned up my old can.
72lb4x4 is offline   Reply With Quote
Old 09-13-2008, 06:20 AM   #4
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Looks great man!!!
I will be adding power steering to my 79 here soon. And when I go see other Chevy's I too see different set ups. I dig the clamp install too!!
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 09-13-2008, 11:47 AM   #5
LMDGUY
LMDGUY's Avatar
nice..
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 09-13-2008, 12:18 PM   #6
Painter D
Painter D's Avatar
Thanks for sharing!
Painter D is offline   Reply With Quote
Old 09-15-2008, 05:46 PM   #7
basketcase
basketcase's Avatar
It sounds like a few of us have the same problems. The guy I got my truck from bought it engineless and gathered parts from various junk yard and parts trucks for it. It's been a mix/match and modify all the way through. I may end up doing some inner fender modifying too.
Tom
Old 09-15-2008, 09:11 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Great idea... thanks for sharing!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
