Old 09-12-2008, 05:10 PM   #1
JoeKan
JoeKan's Avatar
Vin # for 61
Can someone tell me where I can find the vin # on a 61 3/4ton? It is listed on the title, but I can't find it anywhere on the vehicle.
Thank you,
Joe
JoeKan is offline   Reply With Quote
Old 09-12-2008, 05:36 PM   #2
kizer
Its Deja Vu time again
kizer's Avatar
Re: Vin # for 61
My 65 is on the cab on the drivers side. Near the top of the door. So basically if you didn't duck you would wack your head on the same spot.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 09-12-2008, 05:51 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Vin # for 61
It is supposed to be on the upper driver door pillar. if it fell off you should see 2 tiny holes about 3 inches apart, where it was spotted on at the factory.
there should also be the same # stamped in the top of the drivers side frame rail just in front of the a arm.
Old 09-12-2008, 06:07 PM   #4
JoeKan
JoeKan's Avatar
Re: Vin # for 61
Thanks Jon for the information. It is on the door pillar. Thanks also kizer for taking the time to respond.
Old 09-15-2008, 09:30 AM   #5
jchav62
1962 C-10
jchav62's Avatar
Re: Vin # for 61
On 60-63's the vin is on the driver's side door jamb on the front pillar.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
