Foolish Mortal
Window washer pump location
Hi guys-my washer pump hasn't worked since before I owned the truck (although, it may have stopped working shortly after-don't honestly remember. The motor SOUNDS like it's trying to squirt, even though it doesn't work. No matter, I've purchased a rebuild kit for it and I just have one small question....
Can anyone provide a picture of where the darn thing is????!!! Thanks! |
Hollister Road Co.
Re: Window washer pump location
mine is on the wiper motor
I make Models
![]() Join Date: May 2005
dont have a pic but it is on the inside of the truck under the dashboard....if you shine a light up under the dash right between the ash tray and gas pedal you will see it up there.....not much fun to get to either.......
Here is a pict where I think it is at,,,,I found it while stripping the cab out completely....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Truck and auto performance nut
yup....top right of the image above ^
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Just my opinion, take it for what it's worth. I haven't had much luck rebuilding these pumps. And when they start to go bad they leak inside your cab. I like to use an electric inline washer pump (9.99) and connect it in the engine bay. That way if it leaks for whatever reason, I don't have wet carpet/ or the radio doesn't get wet on the backside. Just a thought.
SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#7 | |
Between Trucks...
Beat it to fit, Paint it to match... ![]() |
Active Member
![]() Join Date: Jul 2007
do what I am doing!!!!
get rid of it!!!!
Old member
Here is what I used and it works off the orignal switch also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Between Trucks...
What is that exactly?
Old member
The washer jug came out of a little chevy car. Sorry don't know what it was just saw it and grabed it. It hooks up easly enough though.
The box beside it is my cold air box for the TPI unit. ![]()
#13 |
elektrik , I hope you've already ruled out the obvious. You say the pump sounds like its working, just make sure all lines are clear, filter is clean as well as those little squirters pointing at your windshield. Its amazing what a cutting torch tip cleaner can accomplish!
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. Last edited by Southpa; 09-13-2008 at 09:25 PM. |
#14 | |
Foolish Mortal
#15 |
help new member,need help wiring wiper switch to wiper motor. any help will be helpfull thank you Herman
#16 | |
The Older Generation
Yellow wires at the motor are the 12v+ wires. (Wire leaves fuse box, then runs to motor, then jumps to second pin on motor...see picture) The Dark Blue wire (when grounded) is for the WASH feature. (It's the wire closest to you in the photo) The Black wire (when grounded) is for HIGH speed. The Light Blue wire (when grounded at the same time as the Black) is for LOW speed. (It's the wire that is in the background in the picture) The plug on the back of the switch will only plug in one way. The switch has to be in the hole before it will work because that is the ground connection for it. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-01-2011 at 09:12 AM. |
#17 |
Recalculating.....
subscribed
Brian - (BBrendal) 1969 Chevy Camaro Z28 1972 Chevy Blazer CST 2004 GMC Yukon (The truck that pulls the car trailer) 1972 Chevy Blazer CST #2 (Finished and sold!) Blazer build link... http://s1213.photobucket.com/albums/...rendal/Blazer/ |
#18 |
I know this is old, but I picked up an Anco inline pump today with a power wire and a ground.
What do I hook up to? The red to the dark blue or ? |
