Old 09-13-2008, 01:35 AM   #1
jslater
jslater's Avatar
Another Blower Install
Pic1. Here's my motor before Weiand 142 install.
Pic2. Engine with Weiand setting on top.
List of build up:
1. Weiand 142
2. Modified Holley 700DP.
Current: HP Main Body, Ported for boost referenced PV
50cc secondary pump,
3. Mallory Max Fire distributor w/ ProMaster Coil
Dist is fully programmable w/ boost retard
jslater is offline   Reply With Quote
Old 09-13-2008, 09:25 AM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Another Blower Install
That looks phat. What are the specs on the motor?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-13-2008, 10:50 AM   #3
watahyahknow
watahyahknow's Avatar
niiiiiice
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-13-2008, 04:13 PM   #4
jslater
jslater's Avatar
355 SBC, XE-268 Comp Cam, 1.6 roller rockers, stock (ported) heads, 9.0:1,
1 5/8" Doug's headers, 2 1/2" "H" exhaust, Flow Master Mufflers (Super 40's), Edelbrock mechanical fuel pump, 2800-3200 stall, Built TH350 tranny, 3.73 gears w/ Eaton Posi
Should see between 5-5.5psi boost by the calcs I ran.
Old 09-19-2008, 09:51 PM   #5
jslater
jslater's Avatar
Today I was finally able to finish and take the truck for a drive. I decided to go with Mallory's NEW Maxfire electronic dizzy w/ boost reference. Set initial timing at 16* w/ total at 34*. This dizzy is programmable so I set it retard 1.5*/ # of boost. So drive at part throttle felt great and everything seemed ok. Decided to take it up a bit and BOOM then the engine died. When I opened the hood I found the dizzy cap had blown apart. after talking to Mallory techs they said that this has happened before and the cause was a loose hose connection within the dizzy from the factory and under boost the dizzy pressurized.This really ruined my day.
Old 09-19-2008, 09:59 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Wow... that looks good!!!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-20-2008, 07:49 AM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Looks pretty impressive. Bet that gave you a real scare when the distributor damage happened!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-20-2008, 03:53 PM   #8
shortbed70
shortbed70's Avatar
I am also thinking of that blower. Do you have a part# for the dizzy and what pistons does your motor have?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
