09-13-2008, 01:50 AM | #1 |
Moderator
402 or 454?
I am going to be swapping out a blown 402 big block with a new longblock, and was thinking of going with a 454 instead...all the accessories will bolt up. I was wondering what I would need to change? Do I need to change the flexplate? The 402 is bolted up to a 700r4. I know a flywheel is balanced to each particular engine. I know I will need a different harmonic balancer. Anything else? Thanks!
09-13-2008, 10:38 AM | #2 |
Re: 402 or 454?
454s are externally balanced, therefore you will need the flexplate and the ballancer for a 454. everything else should swap over without any issues.
09-13-2008, 11:48 AM | #3 |
Always on the hunt...
Re: 402 or 454?
with kwmech.
09-14-2008, 02:38 AM | #4 |
Moderator
Re: 402 or 454?
Perfect, I don't think I will have a problem locating either one of those!
