Old 09-13-2008, 11:55 AM   #1
d10s69c10
Built 4 Speed
d10s69c10's Avatar
What brakes do i get?
i got a 69 c10 2wd and i have 5 lug rotors up front. just had a caliper get pretty stiff on me and i need to run to the old autoparts store to get a new one.(or a rebuild). but in the event they have to order one what year do i need to get.
everything appears to be oem so iwas just wondering who knows what would have been the 5 spindle/rotor combo that fit on the 69.
will a 72 work?
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 09-13-2008, 12:17 PM   #2
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: What brakes do i get?
Bump..... i could go snap a pic right quick if it would help.
496/T-56 in worx.
Old 09-13-2008, 01:19 PM   #3
Riveted1
Tasty Cakes!
Riveted1's Avatar
A 5 lug setup on a 69 wouldn't be factory, and that's about all the info I can give you....
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 09-13-2008, 01:24 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
pics would help. There's a couple options of which way they coulda gone.
Old 09-13-2008, 02:04 PM   #5
Southpa
Southpa's Avatar
Yes, you have to investigate and make some comparisons. Obviously someone swapped front ends or brake components with a later year (71 and upwards) to make it disc brakes. Is the rear still 6 lug? If its 5 then the rear end (or axles) were swapped with a later model as well OR you might be mistaken and the truck may not even be a '69.
All 1/2 ton trucks were changed to 5-lug w/ front discs in 1971. There is a good chance that a '71 or '72 rotor is in the truck now. I don't know how different the 73 and up rotors are, best to look at each (71/72 vs. 73 up) and see which one matches yours.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 09-14-2008, 07:55 PM   #6
d10s69c10
Built 4 Speed
d10s69c10's Avatar
thanks for all the help everyone .
turned out i got a 74 1/2 ton setup front/rear. redud the bearings rotors calipers. trucks running awesome.
Thanks- Dustin.
496/T-56 in worx.
Old 09-14-2008, 10:24 PM   #7
Riveted1
Tasty Cakes!
Riveted1's Avatar
Glad you got it fixed. I'd put that info in your notes somewhere so you don't forget. I always think I'll remember stuff like that, and find out that info has been replaced when I the time comes.
