Old 09-13-2008, 05:29 PM   #1
evilways
evilways's Avatar
Balancer issue, need help
I have 283 that I am in the process of adding power steering. I was starting to add a pulley when I noticed no bolt in the balancer? It is threaded (7/16 fine) and I have tapped it out to make sure it is clean. My question is if I get a bolt and washer, does it seat down in the opening on the balancer or does it need to seat on the face of the balancer?
Also bought a add on pulley, it is still about a quarter in off of the power steering pulley, can I add washers to space it out? I can’t move the pump back any do to the brackets, so the add on crank pulley has to come out a bit.
evilways is offline   Reply With Quote
Old 09-13-2008, 05:41 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Balancer issue, need help
The bolt is to hold the balancer in place so it would have to be on the pulley itself. From the pic, it seems that if you put a bolt and washer in, the pulley would be pressed farther back and maybe you won't need any spacers for the pulley.
68gmsee is offline   Reply With Quote
Old 09-13-2008, 06:08 PM   #3
truckdude239
truckdude239's Avatar
my 327 with the balance all the way back it was not seated all the way,(crack shaft did not com all the way to the end of damper) i used the bolt to pull it down then took the bolt out installed the pully then the bolt inside the pully
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-13-2008, 06:42 PM   #4
berencam
berencam's Avatar
you can get a balancer bolt and washer at your local auto parts, then go to lowes, and buy a real good quality bolt with the same thread, use that bolt and the washer and pull the balancer on tight then remove it and replace it with the other bolt, should look something like this when you get done
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 09-13-2008, 07:06 PM   #5
evilways
evilways's Avatar
It's fully seated in the picture; I am confused about the hole though. All balancers I have seen in pictures look nothing like this one.
This was a stock 283 that has had some work done to it, at least a cam and possibly a crank. So am not sure if it's stock or what this balancer is from? The truck was a manual, now its automatic transmission. I don't know if that makes a difference in the crank or not.
I just went and picked up a grade 8 bolt and washer, I am wondering if it sets all the way down in the hole? Or do I mount the pulleys then seat the bolt and washer down on top the pulleys?
Old 09-13-2008, 07:20 PM   #6
truckdude239
my balancer is the same size just the front of it was different
David fuller
2000 Tahoe 5.3l 378
Old 09-13-2008, 07:28 PM   #7
Boog
laying low
Boog's Avatar
You may need to shop around and look at different pullys. They came in different offsets.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-13-2008, 08:55 PM   #8
centsless
sufficiently talented fool
centsless's Avatar
A lot of the 283's did not have a bolt on the balancer. Mine is a 1967 283 Power Pack motor and the crank does not even have a hole in it.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
