Old 09-14-2008, 12:06 AM   #1
bryanschevyparts
who makes the tailight gas door???
can any of you guys let me know who makes them(tail light gas door )or the )side markerlight( for relocating your gas tank i want to buy one thanks in advance
bryanschevyparts is offline   Reply With Quote
Old 09-14-2008, 12:16 AM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: who makes the tailight gas door???
as far as i know, no one makes one. you'll have to build it yourself.
IvelDesigns is offline   Reply With Quote
Old 09-14-2008, 08:27 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
There is a pretty good thread on the side marker fill in the FAQ forum. Scroll down to the bottom of this page and you will see the "Forum Jump" box. Click on the little down arrow on the right side of the box and scroll down to "FAQ Truck Tech". On that page go down to "Sticky: FAQ Index thread" and click on it. When you get into that scroll down to the "Custom Touch" section (almost to the bottom). Also check out the "Custom Gas Filler".
I could have just posted a direct link but there is a lot of good info in the FAQ section and now the people that read this thread will know how to get to it.
Thanks to Krue for indexing the FAQ's
LockDoc
Leon
Old 09-14-2008, 10:49 AM   #4
R.L.
R.L.'s Avatar
I never thought of a 56 taillight gas filler thing but was considering a 80s Camaro type filler behind the licence plate .Depending on the bumper I decide to go with.
R.L. is offline   Reply With Quote
Old 09-14-2008, 11:05 AM   #5
cdowns
cdowns's Avatar
you do when you fabricate it
Old 09-14-2008, 12:59 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
GM had taillights that swung down to access the gas tank, like the '56 Chevy and mid-50's Cadillacs. The '56-57 Mark II from Lincoln had a taillight that swung to one side as it opened. The '57 Chevy had a section of the rear fin stainless steel that swung open.
Many of the mid-50's FoMoCo cars had the filler behind the license plate, where it mounted above the rear bumper. Later GM cars had them behind the license plate, in the rear bumper.
The only problem I would wonder about in the use of a swing-down rear license plate mount would be whether or not you could fill the gas tank if the filler tube was that close to the horizontal plane that mounting the tank and the filler neck would entail.
Member Nr. 2770
Old 09-14-2008, 01:09 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
As mentioned above, it's totally a DIY project...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-14-2008, 08:18 PM   #8
bryanschevyparts
someone on here has the tailight gas door,i guess i will fab one or try to
Old 09-15-2008, 09:50 AM   #9
Putter
More Cowbell....
Putter's Avatar
Here are some. The second one belongs to member "Yank".
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 09-15-2008, 09:13 PM   #10
bryanschevyparts
Putter,your the man!! i wonder if yank has some detailed pics of how he did this ,the one i saw you pushed the top of the tailight ,and it poped open.thanks alot
Old 09-20-2008, 02:37 AM   #11
R.L.
R.L.'s Avatar
Wow ,forget about the license plate thing ( never thought about it being too low to fill),I like the tail light filler now that I've seen it.
Thanks Putter
Old 09-21-2008, 01:04 AM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
If I recall correctly, I think I seen a truck that used a Camaro gas tank and hid the filler behind the license plate.
-Nate
Old 09-21-2008, 11:03 AM   #13
yellowGT
yellowGT's Avatar
I have a quick question.... what type of tank did these guys use to have the neck going to the marker light or to the taillight? I know they are not using fuel cells cause they come out of the top so I was thinking blazer tanks. Let it be known please. Thanks.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 09-21-2008, 12:28 PM   #14
68 short step
ive always use a fuelcellguy (mark) tanks, and the fill tube comes out the side, just above the frame rail
68 short step is offline   Reply With Quote
Old 09-21-2008, 02:25 PM   #15
463
463's Avatar
i was thinking about this mod and the thought crossed my mind that filler may work better for filling if the hinge was reversed to a swing up verses a swing down.
Trueman
463 is offline   Reply With Quote
Old 09-21-2008, 10:42 PM   #16
bryanschevyparts
the tank i will use is from a blazer ,i cant wait to get that BOMB out of my truck
Old 09-22-2008, 08:37 AM   #17
Putter
More Cowbell....
Putter's Avatar
If I recall correctly, Yank used half of a flip-down tag (like the ones found on older Olds/Pontiac/MonteCarlo). Those have a return spring that flipped the tag back up into it's original position. This is how he keeps the tail light closed. (see pic 1 & 2)
Not sure what was used on the teal colored one. If you look closely, it moves completely out of the way. Looks like an actual fuel door hinge like most of use used on our side-marker filler doors.
Old 09-22-2008, 08:48 AM   #18
Putter
More Cowbell....
Putter's Avatar
I found a closer photo of the first one.....this is before he cleaned it up....
Old 09-22-2008, 11:33 AM   #19
HuggerCST
HuggerCST's Avatar
Here's my version.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 09-22-2008, 02:11 PM   #20
Putter
More Cowbell....
Putter's Avatar
Oh....that's purdy.
What keeps it closed though? Magnets?
Old 09-22-2008, 03:16 PM   #21
HuggerCST
HuggerCST's Avatar
Thanks Putter. No magnet, but I may add one. There is a spring on the side that holds it closed. When opened, it cams over and holds it open. I have some pics in this thread that explain it a little better.> http://67-72chevytrucks.com/vboard/s...ht=fuel+filler
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 09-22-2008, 07:48 PM   #22
bryanschevyparts
wynne,that is flat out the nicest one i have seen , i might have just came up with an idea for our trade ??
Old 09-22-2008, 08:25 PM   #23
wHATANERD
wHATANERD's Avatar
here's the link for the 69 Camaro behind the license plate built:
http://67-72chevytrucks.com/vboard/s...d.php?t=243181
This is what I'm most likely going to do to mine.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 09-22-2008, 09:06 PM   #24
HuggerCST
HuggerCST's Avatar
Thanks Bryan, send me a pm with what you have in mind.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
