Old 09-14-2008, 12:32 AM   #1
gottwake
gottwake's Avatar
Anyone have pics of removing the front spindles
I need to take the spindles off and powercoat the crossmember but Ive never taken these things apart. Anyone have pics to share, maybe step by step process or an article of some sort? This is my first real ground up including mechanical, Im more of a paint & body guy.
Blazer Project
gottwake is offline   Reply With Quote
Old 09-14-2008, 01:09 AM   #2
gottwake
gottwake's Avatar
Re: Anyone have pics of removing the front spindles
Also, how do I get the stock upper and lower ball joints out of the A arms?
Blazer Project
Old 09-14-2008, 03:08 AM   #3
Riveted1
Tasty Cakes!
Riveted1's Avatar
I'm assuming this is on the Blazer in your signature? If you don't have one yet, one of those Chilton or Hayes manuals have most of the info you'll need (with pics!)
It's pretty straight forward, just start taking stuff off! To knock the spindle loose from the ball joints, take a BFH to a flat edge of the spindle where the ball joint enters and give it a few good whacks. Some come off very easily this way, and others don't. If not, a pickle fork can be used to pry em out. You can rent or buy pickle forks from most auto parts stores.
As far as the ball joints, if they've never been removed, the upper ball joint will have rivets that will need to be drilled/ground out. The lowers will need to be pushed out. You can buy a kit at Harbor Freight to push em out or take it to a machine shop. I took mine to a machine shop and they charged me $15 per side to push out the old ball joint and put in a new one. Money well spent if u ask me
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 09-14-2008, 06:59 AM   #4
scotts62
One day...
scotts62's Avatar
Yep couldnt have said better
Scott
93 crew cab build
Project 62
Old 09-14-2008, 07:05 AM   #5
LONGHAIR
Be aware that if you "pickle fork" your ball joints apart....you are going to destroy the rubber boots, there is no way around it. Pickle forks are only a viable option if you are replacing the joint, if you are just taking it apart to replace springs or something, the "hammer to the side" method is the way to go.
LONGHAIR is offline   Reply With Quote
Old 09-14-2008, 07:53 AM   #6
see ten
WTB this ad
see ten's Avatar
see ten is offline   Reply With Quote
Old 09-14-2008, 08:02 AM   #7
TimE
Hey Y'all!!
TimE's Avatar
Everyone needs a BFH in their toolbox!!
Good job see ten!!
TimE is offline   Reply With Quote
Old 09-14-2008, 08:27 AM   #8
63sbssbbw
UCA63
63sbssbbw's Avatar
Don't forget about the spring tension
I've wrapped a chain around it and something solid (framerail) with enough slack where it will be loose enough to remove afterward,but tight enough where it won't kill your fender or you
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 09-14-2008, 08:32 AM   #9
panhandler62
Java Mechanic
panhandler62's Avatar
There isn't much spring compression if the suspension is hanging unloaded, but I won't argue with a safety rec out of policy.
If you are removing ball joints that have been in there for 37 years you may find that extream measures, such as chisels and grinders, are needed.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-14-2008, 09:44 AM   #10
gottwake
gottwake's Avatar
Got it, Thanks.
Blazer Project
Old 09-16-2008, 06:00 AM   #11
tdave00
Restoring a 68 SWB
tdave00's Avatar
I just took mine apart with the original drum spindles on it and a BFH did the trick.
tdave00 is offline   Reply With Quote
Old 09-16-2008, 10:05 AM   #12
gottwake
gottwake's Avatar
Yea, I too used a very BFH. I was able to remove the arms and spindles but now I need to get the disk off of the spindle. I'm kinda learning as I go here.
Blazer Project
Old 09-16-2008, 04:21 PM   #13
leftcoast66
leftcoast66's Avatar
Good work. The learning is the best part. There's always a few tricks that you pick up along the way, but its a fun. Just dig in and it'll all work out along the way.
leftcoast66 is offline   Reply With Quote
Old 09-16-2008, 05:29 PM   #14
Riveted1
Tasty Cakes!
Riveted1's Avatar
Don't worry! You're in good company here. I'm still learning as I go too. But I got the info I posted above from this site and my Haynes manual, then got to work! Everything was just like a big puzzle...
Old 09-16-2008, 09:37 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work SeeTen!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-16-2008, 11:01 PM   #16
gottwake
gottwake's Avatar
LOL, its all done but it's funny how once it is all taken apart, you see where you could have taken short cuts or done things differently.
Blazer Project
