Old 09-14-2008, 10:13 PM   #1
Fubar
Fubar's Avatar
Drum vs. Disk brake line size
I have a 69 k10 that I am converting from drum manual brakes to power disc brakes. I have a 3/4 ton booster, m/c and proportioning valve in place, and need to hook up the brake lines to the proportioning valve on the outlet side but the old lines are different size's. I'm wondering if anybody can tell me the right way to connect them.
Fubar is offline   Reply With Quote
Old 09-15-2008, 05:34 AM   #2
JimKshortstep4x4
Re: Drum vs. Disk brake line size
Here is a picture of a 3/4 ton power brake booster as installed. Note the front reservoir of the MC goes to the rear of the prop valve and the rear brake line is routed out the of the rear of the prop valve using 1/4" line.
The rear reservoir goes to the front of the prop valve and is routed to the front discs using 3/16" line from the prop valve.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-15-2008, 04:44 PM   #3
Fubar
Fubar's Avatar
Thank you for the help. And the pic. helps alot too.
Old 09-15-2008, 05:59 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Here's a question that I have. Currently my '68 has drums all around. I am swapping everything over to 4 wheel discs. I found in another post that I can use the factory '68 distribution valve but does it matter if all of the hard lines are 1/4"?
I know later disc/drum trucks use 3/16" lines for the disc and 1/4" for the drum but since I am going all four disc, I would think it should not matter that the lines are 1/4" all around instead of 3/16" all around.
Any thoughts?
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-20-2010, 10:03 AM   #5
66_k10_manny
I have a 66 k10. Im only putting disc brakes on the front and leaving my stock rear drum. My brake line size is all the same. Do I need to change one of the lines to accomodate the disc brakes?
66_k10_manny is offline   Reply With Quote
Old 06-10-2011, 12:19 AM   #6
mmmBoost
good info
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline   Reply With Quote
