09-15-2008, 01:52 PM | #1 |
Studs for Upper Control Arms
I was wondering if anyone knew if you could get longer studs for your upper control arms so you can adjust your chamber correctly while inches off of the ground. I think that I will run out of threads on the stud before I get the wheels where I want them to be. If anyone has a site or anything just let me know. Thanks
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
09-15-2008, 10:23 PM | #2 |
Happy to be here
Re: Studs for Upper Control Arms
Anyone know?
09-15-2008, 11:03 PM | #3 |
I already ordered the new factory sized bolts from LMC. I just might take them to my local machine shop and have him take care of them for me.
09-16-2008, 09:14 AM | #4 |
Any fastener dealer like Fastenal should be able to match up something fairly close. You can always use a longer grade 8 bolt. It doesn't necessariyl have to be a stud, it's just easier.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 |
09-16-2008, 05:35 PM | #5 |
I went to fastenal and they didnt have anything at all. He was looking in the books and still couldnt find anything. Thought about just using a 1/2 grade 8 bolt but that would be a major PITA to get to with the motor in it
09-16-2008, 11:38 PM | #6 |
It'd be alot cooler if you did
why not just cut that section off the crossmember and move it out an inch or so... problem solved.
09-17-2008, 02:19 AM | #7 |
09-17-2008, 10:14 AM | #8 |
I got info on a different way. thanks though guys.
09-17-2008, 11:08 AM | #9 |
67-72 parts collector,…
Care to share your info?
09-18-2008, 10:01 PM | #10 |
x2
I need more adjustment on mine too.
- Greg |
