Dash pad
Anyone care to offer their suggestions as to the easiest and simplest way to remove the dash pad?
Pardon my questions...I'm a noob on a mission. |
Re: Dash pad
The easiest way is with everything else pulled out of the dash. Yeah I know, I only had all my stuff removed because I'm doing a total rebuild. There are about five nuts behind the pad. If you can get your hands/nut driver up in there, it's not bad. It's tougher threading the nuts back on.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
The Older Generation
Re: Dash pad
There is no easy way.... Unless you are a contortionist you will probably need to remove the glove box liner and the instrument cluster and for your sake I hope it doesn't have a radio. To remove the cluster I think you have to drop the steering column down. It's not a two hour job... ![]() LockDoc
its all about the +6 inches
Re: Dash pad
and it gets WAY worse if it is an A/C truck. you WILL cuss the center vent.
Re: Dash pad
Just had mine out,it is harder to get back in,but with the glove box out you can get to at least 3 nuts. If you take off your heat hose to the drivers side it will help get some arm space under the dash to get the other 3.They're the tough one's.Good luck.
Re: Dash pad
you actuallly put the nuts back on?
I don't think I have ever done that. |
Re: Dash pad
Me neither.
![]() That way they`re easier to remove,too. ![]()
![]() Join Date: Jan 2007
Re: Dash pad
![]() Also - when I pulled the dash pad off the A/C parts truck - I wondered why the heck they put the center vent where they did - I wanted to cut the dash to get it out - it was that big of a PITA. Good luck. |
Rusty Nuts
Re: Dash pad
Hey guys for the future when i take mine off, a few of you say not to put the nuts back on. What do you use to hold it in place,double sided tape or velcro or what.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
Re: Dash pad
I use as many socket extensions that I had in my tool box for the one behind the instrument cluster. Mine does not have a/c or a glove box so that side was easy. With that many extensions I was able to turn the ratchet from down by the pedals. It is just a bear to get it started by balancing the nut in the socket but it worked.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
Re: Dash pad
You can put the center ones back on (it wouldn't be such a pain to get to them) - but I would forgo the ones on the very end (that cause you to remove the glovebox and the cluster.
Also - there are screws holding it into the dash as well - so it isn't just the nuts holding it on there. |
![]() Join Date: Jan 2008
Re: Dash pad
I had mine re-covered in Ultra leather,and I put the nuts back on,but not the screws.It looks alot nicer with no screw holes,but it was still secure.It wasn't too bad because I had everything out of the dash.
#13 |
I'm a poor spectator
Re: Dash pad
I'll be putting one on soon, guess i'm not really looking forward to it now.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
