09-15-2008, 09:12 PM | #1 |
Georgia Boy
Rear discs..
Has anyone done a rear disc brake swap on our trucks? If so, did you go the junk yard route or did you buy new? What parts did you use and what years or what company did you buy your rear from?
I've got a rear end out of a 2000 Chevy 2WD that has only 2000 miles on it real cheap and was thinking of throwing it in my 81 GMC. |
09-15-2008, 09:40 PM | #2 |
One day...
Re: Rear discs..
I was going to do the conversion but i can accross a 9in lincoln versi rearend pretty reasonable and went that route, it already had disc
09-15-2008, 09:45 PM | #3 |
Georgia Boy
Re: Rear discs..
This rear also has discs.. and I've got the calipers to go with it.
09-15-2008, 09:47 PM | #4 |
Re: Rear discs..
how does the width compare?
CHEVY ONLY |
09-15-2008, 10:02 PM | #5 |
Georgia Boy
Re: Rear discs..
It's pretty close.. the spring perches are in a different location, but I can just cut them and re-weld them where I need them. Is the 2000 model rear as strong as the stocker I have in there now? I plan on putting some serious power in my truck and don't want it breaking.
09-16-2008, 07:27 AM | #6 |
One day...
Re: Rear discs..
Yea maybe, just one of those things, they are only as strong as you make it
09-16-2008, 11:18 AM | #7 |
Re: Rear discs..
Those rear ends are 6 lug which is going to make things tough if you got 5 lug front rotors. Those rear ends are nothing special, just a 8.5 inch 10 bolt which also came in early 80's and up trucks. Many newer trucks also have the Gov-Lock unit. In stock applications and stock driving, these provide really good traction that a limited slip couldn't, but when raced, they are about as good a grenade.
In short, the rear end you already have under your truck is nearly just as strong. If it's a 10 bolt, upgrade the axles and put a limited slip or locker in it and it should be plenty strong unless you are really abusing and racing it. If it's a 12 bolt, you just need a limited slip or locker for it to be strong. If you must have disc brakes, you can use late 70's Cadillac Seville parts to convert it. There's a write up somewhere on how to do this.
1977 GMC Sierra Grande |
09-16-2008, 03:24 PM | #8 |
Re: Rear discs..
Im installing a Baer brake kit when I get the truck back from paint. I will let you know how it goes.
1973 C10 "Chain Reaction" Street Trucks cover Feb 2012 2013 Silverado 1964 Cadillac |
09-16-2008, 07:31 PM | #9 |
Georgia Boy
Re: Rear discs..
Thanks guys.. it is a 6-lug rear. I'll try to find a write up on the Caddy conversion. Let me know how the Baer kit works when you get it installed, LMDGuy
09-16-2008, 08:29 PM | #10 |
67-72 parts collector,…
Re: Rear discs..
PM OJOE. He did a SSBC disc brake swap on his 1/2 ton crew cab project.
09-17-2008, 10:00 AM | #11 |
Re: Rear discs..
09-17-2008, 09:48 PM | #12 |
Georgia Boy
Re: Rear discs..
That's really not a bad price.. has anyone used that company before?
09-17-2008, 10:03 PM | #13 |
like a rock
Re: Rear discs..
I remember reading about a rear caddy setup for 88-98 trucks somewhere not too long ago. I'll try and find a link. Only thing that may be different is the brackets. It used mid 90s impala ss rear rotors, and used 79-85 seville rear caddy calipers. I believe this caliper was chosen so you could have an ebrake.
09-17-2008, 11:57 PM | #14 |
Wide n'Low
Re: Rear discs..
I took a 78 Lincoln Continental rear which had 11 in. dics already. I had the big ford bearing ends mated to my Dana 60 and narrowed the overall width 2 inches. Since I plan on running a 4 link or similar, I left off the spring perches but left on the e-brake cable mounts. These are also a 5on5 pattern so no issues there.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
09-18-2008, 02:45 PM | #15 |
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: Rear discs..
The truck in my avitar (87 s.b.), had a rearend from an 04 SS truck in it when it was sold. If i remember right i had to narrow it 4" per side because i was running a 10" wide wheel w/ a 3" back space. I had a 14" Baer kit... (rotors and caliper spacers). When i ordered my new axles i had them made with the standard 5" on 5" chevy pattern. Baer would not sell the rotors undrilled or with my 5 lug pattern, so i redrilled them to 5x5 using an old axle flange and a drill press! One hole hits the edge of the original 6 lug pattern but the rest are fine. It was a very cheap way to get 14" brakes (about $400.00) Too bad the matching front kit i bought was $1400.00 !!! The truck runs a 22/24 combo now, and the brakes work awesome!!
09-18-2008, 06:25 PM | #16 | |
Georgia Boy
Re: Rear discs..
09-18-2008, 07:12 PM | #17 |
Re: Rear discs..
Its been about 3 years, but i think it was about 2" wider per side.
09-18-2008, 07:22 PM | #18 |
Georgia Boy
Re: Rear discs..
Hmm.. I might just sell the '00 rear and throw a Powertrax in mine. I saw a low-buck rear disc conversion on the internets I might try.
09-18-2008, 10:43 PM | #19 |
Re: Rear discs..
link to the low buck swap please
CHEVY ONLY |
09-18-2008, 10:49 PM | #20 |
Re: Rear discs..
I have a 80 trans am with a 10 bolt rear with factory disk brakes.....could I just swap everything off of the trans am to a truck rear???
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
09-18-2008, 11:19 PM | #21 |
Re: Rear discs..
wrong bolt pattern
CHEVY ONLY |
09-18-2008, 11:21 PM | #22 |
Re: Rear discs..
09-18-2008, 11:29 PM | #23 |
Re: Rear discs..
i don't know......
anything is possible but not always plausible
CHEVY ONLY Last edited by joe231; 09-18-2008 at 11:30 PM. Reason: . |
09-18-2008, 11:35 PM | #24 |
Hey Y'all!!
Re: Rear discs..
I personally don't care much for these. I had a 81 TA and the brakes weren't as good as I thought they should be. The calipers were about $100 each about 8 years ago when I replaced them on that car too.
