Old 09-16-2008, 06:20 AM   #1
tdave00
Restoring a 68 SWB
tdave00's Avatar
Air ride with no compressor
Initially I do not plan on running compressors - just schraeder valves. If I wanted to install a tank, what inexpensive options do I have for maintaining ride height just using the air in the tank. I would just air the tank up manually periodically. Excuse my ignorance, but it's my first time using bags.
tdave00 is offline   Reply With Quote
Old 09-16-2008, 06:33 AM   #2
ZZ4Blazer
Re: Air ride with no compressor
If your gonna plumb in the tank, I dont think you've got too many options without running a decent set of valves.
You can always go manual to keep the price down. Then just plumb it up like a regular system.
Or keep the schraeder valves to fill the bags. Have extra air line from the tank, to reach each of them(or like the coiled style line that expands) and just fill them like that.
ZZ4Blazer is offline   Reply With Quote
Old 09-16-2008, 06:39 AM   #3
tdave00
Restoring a 68 SWB
tdave00's Avatar
Gotcha. Thanks for the input. I figured there wasn't a way to do it without valves. If it's all plumbed tight how often should the bags require more air - weekly?
Old 09-16-2008, 06:48 AM   #4
ZZ4Blazer
If you have everything air tight, and I mean NO leaks, then I woudnt see why it would need more than that.
Old 09-16-2008, 07:35 AM   #5
tdave00
Restoring a 68 SWB
tdave00's Avatar
Thanks, just thought it might require some maintenance with temperature changes and such.
Old 09-16-2008, 08:28 AM   #6
LowSmoothCool
Jon@AirRideTech
LowSmoothCool's Avatar
Temp change would have to be pretty dramatic even then it may only vary between 5 and 10psi. I am mostly concerned why you would want to go with Air and not include a compressor system? The biggest advantage of Air is the ability to lower and lift the truck and make changes to the pressure to improve ride quality and performance
Selling The best Damn Air Suspension
www.ridetech.com
jon@ridetech.com
(812) 482-2932
LowSmoothCool is offline   Reply With Quote
Old 09-16-2008, 08:52 AM   #7
tdave00
Restoring a 68 SWB
tdave00's Avatar
One word - MONEY! I do plan to eventually plumb it for a tank and compressor, but right now I have other things that are a higher priority. I figured as long as I am tearing my truck apart I might as well go ahead and get the bags in, plus I understand that I should have better ride quality with them.?.
Old 09-16-2008, 09:06 AM   #8
LowSmoothCool
Jon@AirRideTech
Gotcha I completely understand... I do have air fill kits which are the airkit90 which sell for 35.00 let me know if there is any thing I can help you with...
www.ridetech.com
jon@ridetech.com
(812) 482-2932
Old 09-16-2008, 10:09 AM   #9
tdave00
Restoring a 68 SWB
tdave00's Avatar
Thanks, and I will let you know.
Old 09-16-2008, 08:36 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
tdave00- What you can do is buy a tank from Wal-Mart like the one pictured below. Fill it and carry it as a back up, or if you get the urge to dump your bags at the local cruise. Just make sure you know that it has enough air to refill your system before you air out.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-16-2008, 09:28 PM   #11
scotts62
One day...
scotts62's Avatar
Yea no kidding, that would be a pain, but i guess you would know where all the stations with free air are around town
Scott
93 crew cab build
Project 62
