Active Member
![]() Join Date: Jul 2007
OK, I need help from rear axle gurus...
I am rear axle challenged and my 68 GMC 250 standard with a Dana has been making a clunking sound when I turn. It's mostly on the first turn after sitting for a day or two.
About 6 months ago I replaced the pinion oil seal, removed rear cover and cleaned and replaced the gear oil and cover gasket. Here's what I have checked for: Loose bed bolts, axle spring bolts, shackles, lug nuts, shocks, etc. all look good. What I noticed: I lifted the rear tire and pushed and pulled on it and found it had a slight in and out movement. Maybe 1/8th inch movement or slightly more. Could this be it? What's the fix? |
Thread Killer!
Re: OK, I need help from rear axle gurus...
Is it a Posi?
Did you put any posi additive in when you refilled it? I'm not sure about a Dana rear but on the 12 bolt that side to side play is normal, The axel is held in place by a "C" clip and there is some play in it.
71 Cheyenne SWB LS1 and auto. http://67-72chevytrucks.com/vboard/s...d.php?t=256470 _____________________________________ If it's worth doing, it's worth doing twice... _____________________________________ Don't Mistake Honesty for Negativity... Last edited by 71BB_LWB; 09-16-2008 at 12:18 PM. |
its all about the +6 inches
Is this a 1500 or a 2500 GMC? (6 or 8 lug wheels)
Active Member
Thanx for responses...
The truck is a 68 GMC 1500 series, 3.54 Dana with 10 bolt rear end. No positraction. Not sure what grease I used but I can find out... bought it at Auto Zone. Now, as I mentioned, I've only noticed the noise only when it's cold and I'm turning. One other thing I forgot to mention. I have removed the sides of the bed before and haven't rewelded them back to the bed. That's sort of a long shot since I notice it mostly on the first turn and not on subsequent turns. |
