Old 09-16-2008, 10:19 AM   #1
thump16
thump16's Avatar
fan wiring
I was wondering if anyone here is running a dual electric fan set up and if so do you have a diagram or info on your set up? I currently have two 14" fans with a hayden 226204 fan relay kit. Would I need to run another bigger relay for the additional Fan? The instructions show an optional fan but I want to make sure I install it right the first time.
thump16 is offline   Reply With Quote
Old 09-16-2008, 01:46 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: fan wiring
You'll find a kinds wiring diagrams.
Harnesses have options for single or dual fans. I've run both.
I currently use a Painless wiring harnes. It runs both fans. It has extra thick wiring. It helps since I use a 145 amp alternator.
Here are a few examples:
http://www.fordmuscle.com/archives/2...cfan/index.php
http://www.s-10crewcab.com/%7Ehenryj/fans/fans.html
http://www.s-seriesforum.com/how-to-efan.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 09-16-2008, 06:42 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Re: fan wiring
Try this on for size. I am running a couple wiring set ups from this company and they work real well.
http://www.spalusa.com/fans/automate...85FH-195FH.pdf
piecesparts is offline   Reply With Quote
Old 09-17-2008, 01:18 PM   #4
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Re: fan wiring
Question on what deg to get. If you running a 180 deg thermostat should you get the 195 deg relay? or the 185 deg. relay?
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 09-17-2008, 08:39 PM   #5
gchemist
gchemist's Avatar
Re: fan wiring
Get the 195 or your fans will be on all the time.
