Old 09-16-2008, 12:04 PM   #1
6772owner
Gearhead
6772owner's Avatar
LT1 Swap
Hey everyone, wanted to see some pics of LT1 swaps, im working on one in C10 and wanted to see come pics of clean swaps. Lets see your work!
6772owner is offline   Reply With Quote
Old 09-16-2008, 04:37 PM   #2
clay68c10
clay68c10's Avatar
Re: LT1 Swap
Rocrin has an LT1, there's a couple of others too.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-16-2008, 05:01 PM   #3
tphsmith
still buypickupparts
tphsmith's Avatar
Re: LT1 Swap
I need to get a/c lines in and a few misc. and I will be able to turn the key to start it. I have not posted pictures for a few reasons, maybe I need to be a supporter?, and wow when people post pictures and ask for opinions its like in my opinion throwing fresh meat to grizzly bears, you dont want to be near the vacinity unless your tuff as steel. but the LT1 sure looks sweet in my opinion in my 72
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 09-16-2008, 05:23 PM   #4
svgould
Active Member
svgould's Avatar
Re: LT1 Swap
Here is a couple shots of mine. It still needs cleaned up, A/C completed, and battery moved to other side so I can change where intake/filter sits. Go easy on me
Shane
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 09-16-2008, 05:35 PM   #5
tphsmith
tphsmith's Avatar
Re: LT1 Swap
looks sweet SV
Old 09-16-2008, 06:59 PM   #6
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Re: LT1 Swap
I have a complete aftermarket wire harness for a LT1/700r4 swap and a computer to run it all.... Its just collecting dust in my garage. not trying to hijack or anything, just trying to help.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 09-16-2008, 09:21 PM   #7
Hoffa
Hoffa's Avatar
Re: LT1 Swap
Nice work Shane - brake booster is trick.
This is a work in progress, so go easy on me too. Runs great, I like the six speed and hydraulic clutch. Currently reworking motor mounts back to stock and relocating the A/C compressor.
I have also included a picture of a buddies LT1 in a 66 burb. He has stock motor mounts and has relocated the AC compressor.
Name:  AC Bracket Picture.JPG
Both motors are Camaro motors. Hope this helps.
68 Chev SWB 2WD w/'95 LT1, 6spd, 4:56, 17" whls - family owned since 1973.
70 GMC LWB 4WD w/RAMJET 350, 4spd, 4inch lift, 33" tires, Warn Winch
72 Chev Blazer CST, 350, TH350, 4WD, factory A/C, tilt, radio delete, 77K miles, orig. paint/interior
Hoffa is offline   Reply With Quote
Old 09-16-2008, 11:07 PM   #8
andrewt2
andrewt2's Avatar
Re: LT1 Swap
i dont have mine wired yet but its on the frame with the 4L60E behind it. wheres the best place to get driver side a/c mount brackets? or best place to get the wiring for it? thanks in advance.
andrewt2 is offline   Reply With Quote
Old 09-17-2008, 12:37 AM   #9
Hoffa
Hoffa's Avatar
Re: LT1 Swap
I got my AC brackets from Bowers Rod Shop (www.bowersrodshop.com). It isn't flashy like some, but functional, well done, and well priced. A fraction of the billet stuff.
I modified the stock harness for my application/programming, so not sure where to go there.
Old 09-17-2008, 03:48 AM   #10
Wreckless_71
Wreckless_71's Avatar
Re: LT1 Swap
Jeezz guys... what are you guys scared about? "go easy on me"??? As far as i'm concerned, not a whole lotta people can go hard on you guys for having balls and pulling off this swap. They look awesome guys and I only wish I could do something like that!
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 09-17-2008, 12:19 PM   #11
andrewt2
andrewt2's Avatar
Re: LT1 Swap
has anyone done a wire by wire thread on how to weed out what you need? i would almost pay if someone put that together to get it done.
Old 09-17-2008, 01:05 PM   #12
6772owner
Gearhead
6772owner's Avatar
Re: LT1 Swap
There are several "how to wire" break downs of the LT1 harness. I did it myself and it wasnt too terrible. I can point you in the right direction if you need help.
Old 09-17-2008, 01:38 PM   #13
andrewt2
andrewt2's Avatar
Re: LT1 Swap
any books to check out or anything websites to check. would love any advice and insight you can give. thanks.
Old 09-17-2008, 08:29 PM   #14
tphsmith
tphsmith's Avatar
Re: LT1 Swap
for info I used, I went to www.shbox.com and www.LT1wiring. com and Granny's they all have very good info, keep in mind, dont do what I did, I sent the computer off for reprogramming and in the mean time, I need to say less then 2 weeks to get my computer back I bought a diffrent cam and fuel injectors and didnt tell the guys who worked on my computer till much later and I talked to them and well I had to get it reprogrammed, not expensive but still additional cost I didnt want. so keep in mind when you get it reprogrammed dont change your mind in the middle of the stream, YOU'LL GET WET
Old 09-17-2008, 10:24 PM   #15
skchevota
skchevota's Avatar
Re: LT1 Swap
I had an LT1 in mine before the diesel. I loved that engine. as for wiring, I reworked the factory harness as well. I used diagrams from lt1.com, some site on geocitys i found, and a hayns manuel. The hayns manuel was the best help. I just highlited all the power leads, and then traced them in the harnes with a test Meter. Then i ran those to an auxilery fuse box. I used a vats moduel from fuel injection.com, and ran a stock computer. I was going to have it reprogramed because i deleted all the emissions stuff and it always threw those codes, but I swapd in the deisel insted.
skchevota is offline   Reply With Quote
Old 09-18-2008, 09:11 PM   #16
pdr510
Junior Member
pdr510's Avatar
Re: LT1 Swap
Is anybody running PaceSetter headers on their LT1? I am running regular SBC Hooker Super Comp's and would like to swap to the PaceSetter. Part number: 72C2239
pdr510 is offline   Reply With Quote
Old 09-18-2008, 09:17 PM   #17
pdr510
Junior Member
pdr510's Avatar
Re: LT1 Swap
Shane
That is nice! Where do you have the ECM mounted?
1970 C-10 Fleet Side
Gen IV 6.0 with 4L80E
Old 09-18-2008, 09:35 PM   #18
pdr510
Junior Member
pdr510's Avatar
Re: LT1 Swap
Here is a pic of mine.
Old 09-19-2008, 10:50 AM   #19
svgould
Active Member
svgould's Avatar
Re: LT1 Swap
Its mounted right under the glovebox cardboard liner. I built a bracket and it tucks up out of the way quite nicely. It may have to move if/when I add A/C though.
1971 SWB SOLD
  • 4" rear springs
Old 09-19-2008, 10:54 AM   #20
svgould
Active Member
svgould's Avatar
Re: LT1 Swap
Usually anytime posts anything to do with the LT-1 somebody always starts the "why go with LT-1, the LS series is sooooooooo much better" conversation!!
1971 SWB SOLD
  • 4" rear springs
Old 09-20-2008, 10:43 AM   #21
faribran
Re: LT1 Swap
so.. elaborate..... how well do yall like the LT1 setup??
faribran is offline   Reply With Quote
Old 09-20-2008, 07:09 PM   #22
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: LT1 Swap
low'n slow is offline   Reply With Quote
Old 09-20-2008, 10:29 PM   #23
skchevota
skchevota's Avatar
Re: LT1 Swap
I did mine back in 99, the ls moters were bank back then, I loved my LT-1, I sold it to a budy who droped it in a 70 nova, he loves it too. I would say price would be the main reason.
Old 09-20-2008, 11:53 PM   #24
cwolley
Re: LT1 Swap
Hey i have a 67 stepside long box wanting to make it a short box. How much do i cut out of the frame?
cwolley is offline   Reply With Quote
Old 09-20-2008, 11:54 PM   #25
cwolley
Re: LT1 Swap
Hey i have a 67 step side long box want to make it a short box. How much do i cut out of the frame?
