Old 09-16-2008, 12:12 PM   #1
Texas1971
One thing leads to another screw up
I pulled the steering wheel and etc. to replace my turn signal switch. In the process of fudging around, I shifted the lever out of park (where it was when I removed everything. Can I just try to put everything back and it will be able to shift BACK into park or have I created a problem for getting everything back together. Thanks in advance!
Texas1971 is offline   Reply With Quote
Old 09-16-2008, 12:20 PM   #2
Putter
More Cowbell....
Putter's Avatar
Re: One thing leads to another screw up
You should still be good. The lever will go back into place from any gear 'position'. (Or at least mine will?!?!?!)
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 09-16-2008, 12:32 PM   #3
Texas1971
putter,
you mean it will go back once everything is back together, right?
Old 09-16-2008, 07:18 PM   #4
heavy71chevy
heavy71chevy's Avatar
Im alil unsure on what your question is...but if im understanding you correctly you dont think it will go back to park? Theres no saftey lock for the gear selector in 67-72s ..should go right back into park
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 09-16-2008, 08:38 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you should be able to shift it in park as it sits, or, you can wait till it's put back together. The steering and turn signal are 100% seperate from the shifting.
Old 09-16-2008, 09:47 PM   #6
Jtrux
I'm a poor spectator
Jtrux's Avatar
Another San Antonio guy, how cool.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-17-2008, 11:33 AM   #7
Texas1971
Thanks to all who replied. Once the indicator switch was screwed back in iver the plate and bearing, all is well in the shift lever, now.
