Old 11-18-2002, 06:25 PM   #1
Low68
Low68's Avatar
brakes
Does anyone know how much how much vacuum I would need for a stock power brake booster? What are some options that I can do if it is too low? Also, I am running my vacuum line from the back of the carb and directly to the power booster. Is there supposed to be anything in the line. Before last summer, it had something in the line. It was shaped like a fuel filter. Is it important? Thanks
Low68
Build Thread
Low68 is offline   Reply With Quote
Old 11-18-2002, 06:56 PM   #2
jmil1974
Ain't we cute?
jmil1974's Avatar
You should run the vacuum line directly from the manifold. I T'd mine off the vacuum line to the tranny and it works fine. I think 14-15 inches of vacuum is what's needed to run power stuff properly. If you don't have enough, you can get a pump to to provide all teh vacuum you need or a storage canister/reservoir that should do fine. That filter keeps oil, gas, and other fluids out of your booster, supposedly prolonging booster life.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
Old 11-18-2002, 07:40 PM   #3
Low68
Low68's Avatar
Thanks for the help jmil. I appreciate it.
Low68
Build Thread
