09-16-2008, 02:38 PM | #1 |
WTB: 68 350 turbo trans shift linkage
I'll just say this, it was a bad day with hurricane force winds, lost power, in the middle of engine r/r with only 12 hours before it had to be up and running for work....
Needless to say... the Braile method of engine instalation isn't for the faint of heart.... I Bent the crap out of my shift linkage and I'm not sure that I'm going to get it straightened out. Here is what I need, I need the rod that goes from the frame hole over to the transmission. Every thing else seems to be salvagable. Any body know what I'm talking about? This is not the later model like 70-72 this is early 68 stuff and it's just a rod with and eye for the down rod off the column linkage and it goes over to the trans. Thanks......... |
09-19-2008, 08:24 AM | #2 |
Re: WTB: 68 350 turbo trans shift linkage
OK...who can help soba_03 out?
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-19-2008, 11:01 AM | #3 |
its all about the +6 inches
there were no TH350s in 68.
You got a photo of what you need? |
09-19-2008, 11:06 AM | #4 |
Moderator
Check out the shift linkage made by Kugel Komponents. It is universal and works GREAT. You can adjust it and dial it in for perfect shifting. Runs about $50 It was VERY easy to install too.
09-19-2008, 03:02 PM | #5 |
I don't know if this will work But this is what is ON the truck. I hate unknown modifications. according to the picture "the Lever assembly" is what I have bent. OK the Picture I've found above shows it's linkage for 73-79 Turbo 350. Why the Heck it's on my 68 I don't know but opens up more posibilities for parts. This is the set up I have except for the spring o the end of my shift lever. Shifting into gear before was kinda like a educated guess any way. But with years of driving it this way it wasn't a problem. Last edited by soba_03; 09-19-2008 at 03:10 PM. Reason: addl info. |
09-20-2008, 10:54 AM | #6 |
Junior Member
I have a 350 complete shift linkage that I am selling in my post. Take a look a see if it will work for you. I mount it to use but have decided to go with a differnent tranny. Check out no. 5. Louie.
http://67-72chevytrucks.com/vboard/s...d.php?t=302721
68 LongStep 350/ 3 Spd (ongoing project) 04 Suburban Z71 (daily driver) 97 C5 Corvette ( sold when 2nd baby came) 90 454SS pick up (sold) 1970 Chevelle Malibu 454 For Sale $8,000. my art website http://www.louietrangallery.com/ my 68 Longstep...No Shortstep Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=296736 |
09-21-2008, 07:12 AM | #7 |
Storm,
I see that is what to me looks like 70-72 shift linkage. I'm so bad at this stuff. From what I've seen in other posts on the subject I'm not sure what all pieces I need to make that style linkage work. I know after looking yesterday that I actually still have the "u" shaped frame bracket mounted to my frame. But the piece that goes from that bracket to the frame is missing. Additionally, the trans in there now has the linkage pictured and I just need the "lever assy" Current set up seems pretty simple. I'm headed to a yard here in an hour or so to try and get things squared away. I'll let you know. Does anyone have an expanded view of the 70-72 linkage set up it looks like it's about all the same but I need the diagram to see how it's all supose to go together. Thanks for all your help to this point. ENG is in and should be running today if everything goes right. I hope. cross your fingers for me . |
09-21-2008, 10:37 AM | #8 |
Moderator
Save yourself headaches, hassles, and gas. Get a Kugel komponents linkage setup, and you will never have a problem again. Your truck will shift like it is brand new and will have NO slop in it. You will also be able to dial in your shifts so that the shift indicator lines up perfectly. Factory linkage has too many pivot points and eventually it wears out.
09-21-2008, 10:44 AM | #9 |
Moderator
http://cgi.ebay.com/ebaymotors/1967-...spagenameZWDVW
here is a link showing some pics of it on ebay ( i wouldnt buy it off ebay, just to give you some more info) |
09-21-2008, 05:04 PM | #10 |
Gettin By on Gettin By
You can always try Lokar. I put one on my 69 with a th400, looks like its going to work out great.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
09-21-2008, 05:24 PM | #11 |
Moderator
09-27-2008, 05:36 PM | #12 |
Leddzepp,
Ok followed your word, question, did you have to bend your rod to make it work? Just courious. It will be here Wednesday. Cheap and way worth it after hasseling with this dam thing for over a week. As a side note, motor is in and OMG I've created a monster...LOL It's the first one I've ever build from bare block up, it's a wee bit more radical than I expected. Thanks for the info... |
09-28-2008, 03:46 AM | #13 |
Moderator
I did not have to bend the rod....you got the longer of the 2 offered, correct? I did not have to adjust it down too much. I put the shift arm on the splined shaft in the 9 o'clock position and adjusted it from there. The instructions are very easy to follow.
