09-16-2008, 05:13 PM | #1 |
Tasty Cakes!
Bagged w/Rallies? And Police Caps? Maybe?!?
Did some searching and reading, but I find the search feature on this forum somewhat HORRIBLE. And I know this topic has probably been run into the ground, but the threads I found weren't exactly what I was looking for.
Planning on going w/some 15" rally (or rallye, if u must) wheels on my '67 for the time being. It's bagged (2.5" spindles up front) and I have 255/60-15's for the front and 275/60-15's for the back. So are any of u guys running a similar setup? Kinda curious as to what width wheels I should go with front and back. Pictures would be awesome. I guess if you're truck isn't bagged, that's ok too, but it's gotta be LOW! Also, do the police caps fit the front hubs on our trucks? Or am I stuck going w/the later model or corvette style caps? My trigger finger is getting itchy on the "purchase cart" button, but I don't wanna pull the trigger until I'm sure I'll like what I order! Thx in advance!
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
09-16-2008, 05:27 PM | #2 |
Old Skool Club
Re: Bagged w/Rallies? And Police Caps? Maybe?!?
I'm running ECE suspension components, but with a static drop....see my signature.
For wheels, I'm running Vette-style rallye wheels, with hot rod trim rings and police caps. I stayed with the 6-lug setup, and I don't regret it. The only issue I have with the police caps is that the grease cap on the front axles will come into contact with the back side of the cap....if your aren't careful, you'll have a dimple on the cap. I'll throw a pic in, after I resize one.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-16-2008, 05:32 PM | #3 |
Tasty Cakes!
Ya I'm staying 6-lug too. What width are your wheels?
09-16-2008, 05:39 PM | #4 |
Old Skool Club
Let's see if I can attach a picture. Had some difficulties attaching one to the post as an edit.
Apparently, not. I've posted pix before, but now it tells me that it's too wide, so I re-size the picture to the size requested only to have it tell me that the picture size exceeds the limit. By the time I get through resizing the picture, you won't be able to see it. Beats me how some of these pictures are large X huge, and I can't even get a properly-sized picture to upload.
09-16-2008, 05:41 PM | #5 |
Old Skool Club
8's up front and 10's out back. I used a 4-inch backspace up front and a 5-inch backspace in the rear. It's perfect. Everything fits within the confines of the outside of the fenders and nothing rubs anywhere.
P.M. me and send me an email address and I'll send you a picture.
09-16-2008, 07:49 PM | #6 |
No bags and chrome rallys. But 3.5/5 drop and police caps. Same tires as you. 8's with 4" bs up front and 10's with 4.25 bs out back.
71 Cheyenne SWB |
09-16-2008, 08:11 PM | #7 |
Tasty Cakes!
Those rear wheels look like they would hit the fender if I tried to air out my suspension. Kinda hard to tell from the pics. Maybe the .75" difference in BS is too much?
Truck looks great, BTW!
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 09-16-2008 at 08:11 PM. |
09-16-2008, 08:54 PM | #8 |
One thing to watch out for when comparing with others is that the 67-69 rear ends are narrower then the 70-72 (by 1.5 inches or .75 inches on each side). Sorry, I don't have the overall face to face dimensions handy. This will play with the backspace that you will want to order.
On the tire rub issue, do you have a stock frame or has it been c-notched? I have a 1970 (wide housing) in my 68 with rear bags and stock frame. I have 17x8's with 4.5BS in the front and 17x9.5 in the rear with 5"BS in the rear. I run 255/60 in the front and 275/60 in the rear. When I blow all the air out of the rear bags, I hit the bump stops without hitting anything else. Based on what I understand yoou are going to do, I woul expect me to rub before you. Attached is a picture at ride height. Hope this helps
68 Chev SWB 2WD w/'95 LT1, 6spd, 4:56, 17" whls - family owned since 1973. 70 GMC LWB 4WD w/RAMJET 350, 4spd, 4inch lift, 33" tires, Warn Winch 72 Chev Blazer CST, 350, TH350, 4WD, factory A/C, tilt, radio delete, 77K miles, orig. paint/interior |
09-16-2008, 09:45 PM | #9 |
fugedaboutit
cool truck
Currently truckless |
09-16-2008, 10:21 PM | #10 | |
Tasty Cakes!
My frame is C-notched. I didn't really want this to turn into another "Will this backspace work?" thread, but it seems to have gone that way. It's just such a small difference between what will and what won't work AND what looks good. LOL BTW, very nice truck!
09-16-2008, 10:51 PM | #11 |
Thanks guys.
It sounds like you have settled in on a look you are shooting for, so in my mind the backspacing is everything at this point. I have a buddy that didn't put much thought into it and got the wrong backspacing. It is fine 80% of the time, but he is always worrying about rubbing. Hopefully you can find someone with a similar setup that can help you decide. A good wheel vendor should be able to help out too. In my opinion, if you have the stock rear you are probably looking at the 4.25 in back and 4.5 in the front (based on 10's & 8's respectively). Good Luck.
09-16-2008, 10:57 PM | #12 |
I don't know what "police caps" are, but here is mine before I dropped the front a little more and fixed the rear-end.
BTW - I'm not sure if I will keep the color pattern on the wheels
R.I.P. Scott Kalitta
09-16-2008, 10:59 PM | #13 |
I'm bagged with rallys and disc brake caps.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht Last edited by hotrodhomi; 09-16-2008 at 11:01 PM. |
09-16-2008, 11:18 PM | #14 |
I have a radical idea!
Here's a few different combinations of lowered trucks with ralleys.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
09-16-2008, 11:49 PM | #15 |
*NO REGRETS*
I know this isn't what you are looking for but just thought you or others might like it if there isnt already a thread on this truck. NOT MINE BY THE WAY but super clean in person! His streetsource profile reads....15" smoothies with baby moon centers 215/65/15 up front & 225/70/15 in the rear....if this even helps?
09-16-2008, 11:52 PM | #16 | |
That truck is KA-LEEN!!
09-17-2008, 09:06 AM | #17 |
Insert Title Here
Not all what your looking for.....but worth looking at
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 09-17-2008 at 09:08 AM. |
09-17-2008, 09:07 AM | #18 |
Insert Title Here
09-17-2008, 09:07 AM | #19 |
Insert Title Here
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
09-17-2008, 09:23 AM | #20 |
Tasty Cakes!
Hotrodhomi and Houp, can u guys gimme specs on your wheel size and backspacing?
And Rustspot, yes that truck is amazing. My favorite part of it is the inside of the bed! And thanks so much for all of the pics guys! My head is spinning! I see a couple in there w/the exact look I'm going for. This guy nailed it IMHO, but these wheels look larger than 15's:
09-17-2008, 07:53 PM | #21 |
Tasty Cakes!
Ok so I went out there today to do some measuring and now I'm even more confused. Summit only carries the 15x10 in a 5" BS or a 4.5" BS. I have the narrow rear, and with a 5" BS on a 10" wheel, it looks like I'll be into the inner part of the rear fenders when I air it out. The 4.5" BS looks like it'll fit, but just barely.
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 09-17-2008 at 08:09 PM. |
09-17-2008, 07:58 PM | #22 | |
09-17-2008, 08:04 PM | #23 |
Old Skool Club
1LoC10 posting of the primered truck looks like the one to get the skinny on. Since it is obviously aired-out, knowing what size wheels are on it should help determine what would/wouldn't work.
The silver truck looks nice, but (my opinion) the primered one is key.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 09-17-2008 at 08:05 PM. |
09-17-2008, 08:28 PM | #24 |
Tasty Cakes!
You talking about this one? My truck isn't that low.
This one is more like what I'm shooting for... albeit a tad bit lower in the rear.... The pic below is how my truck sits w/the current 15's:
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 09-18-2008 at 04:42 AM. |
09-18-2008, 07:01 PM | #25 |
Tasty Cakes!
Bueller.... Bueller....
