Old 09-16-2008, 05:33 PM   #1
murdoc
murdoc's Avatar
will a 68 column interchange with a 65?
i have a three speed on the column in my 65 that is really sloppy, i recently found a guy thats parting out at bone stock 68 that has a really tight 3 speed column in it. does anyone know if they are interchangeable?
murdoc is offline   Reply With Quote
Old 09-16-2008, 05:50 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: will a 68 column interchange with a 65?
I've been told they do.... but don't hold me to it. I HOPE someone can chime in.
Do you have measurements on a 65 column?
Old 09-16-2008, 06:31 PM   #3
fake.happy
low_standards
fake.happy's Avatar
I put a 70 3 speed auto column in my 64. Had a few mods to make. The 64 has 3 holes in the firewall where the lower column goes through and bolts to the firewall and the 70 column only has two holes. my 64 has an upper steering column mount that uses two bolts so I had to drill into the 70 column and weld in two nuts. After that it fit just fine and the length doesn't seem to be much different but I won't really know untill I actually hook up the steering shaft someday. Just because I pulled it out of a 70 doesn't make it a 70 but I'm pretty sure that it is. sorry that I don't have any pictures of it in the truck but I just pulled the column off the shelf and unwrapped it for pics. I got sidetracked with other projects so I haven't touched the 64 in last 5 months. Hope this helps a little.
If you ever need help
don't hesistate to ask
someone else first
fake.happy is offline   Reply With Quote
