Old 09-16-2008, 11:09 PM   #1
frankyjoet
Unhappy hei dist
What are the symptoms of a bad dist module? 73 gmc lbed
engine running rough
frankyjoet is offline   Reply With Quote
Old 09-16-2008, 11:27 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: hei dist
pickup coil or the module? usually modules either work or dont you get no spark... the pickup coil that usually means there is weak spark or you get no spark when you try to give the motor gas
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-17-2008, 02:14 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: hei dist
I sit a swap you just did, or has it been in a while? 73 originally had points...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-17-2008, 07:47 PM   #4
screwballl
Tonawanda 454
screwballl's Avatar
Re: hei dist
if it is a HEI setup: when I had the problem (on my 76 C1500) the truck would run until it got hot and then just die... if it was hot summer day it would be a matter of 5 minutes, if it was a cooler day it would run for 20 minutes... either way it would just die. I could let it sit for a minute then it would fire right back up and die again 2 minutes later... had to do this on my way to work which is usually a 7 minute drive... took me 20 minutes to get there... Luckily it was cool that night on the way home so I got 2 houses away before it died so I just put it in Neutral and coasted home.
I tried the coil, HEI, rotor, dist cap, plugs, plug wires... until I talked with a chevy tech down the street (he works at a chevy dealer/repair shop and has for 20 years) and he said on these older ones check the module or the fuel pump.
Sure enough as soon as I replaced it the module it worked fine, never had a problem since (well I sold it a year later but still see it around town).
In your case, I would say check the usual plugs, wires, rotor, etc... and the coil may not be giving enough spark causing the roughness... or it could be the fuel pump getting ready to go out... I am sure it could be a few other things but we would need more info.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 09-27-2008, 09:15 AM   #5
manimal
manimal's Avatar
Re: hei dist
does it "POP" through the carb or exhaust? Run a compression test. I have had several trucks the ran rouhg and did COMPLETE tune-ups just to find out I had a burnt valve.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
