09-17-2008, 08:53 AM | #1 |
WIW - 1 ton c-k conversion project - a 4x4 1 ton LongHorn
Ok, so not sure I am selling yet, but I started to think about a new GMC Quad cab as a hauler, I can get one cheaply and I have a ton of rebate $ from using my GM Credit Card. I also have too many projects and I am burning out. I am looking at a decent NEW truck in the sub 10K range when all is said and done.
So, here goes... the build link is in my signature. It's a LongHorn these days, converted to 4wd Front Axle: 4.10 D60 front, cross over steering, dropped pitman arm and a 2wd box. I also have a posi lock from a CUCV axle that can go in this. All new bearings, brakes and seals. Rear Axle: Corp 14B rear, Detroit locker (still in the box), Disk brakes with ebrake. Suspension: DIY4X brackets that mount 3/4 ton rear 52" springs in the front, a shackle flip in the rear with 56" 1 ton springs. Custom shock cross member. Engine: Cadillac 500, MTS 15 Cam, MTS Roller Shaft mounted Rockers, Edelbrock intake, ported and polished 120CC heads. Stock reciprocating assembly. new timing chain, lifters, rings and bearings. Custom engine mounts and cross member. DUAL transfer cases: (NP203/NP205), all new bearings and seals, everything else looked good. Bling aluminum covers Trans: Cadillac Th400 with a Chevy 203 output shaft. Freshly rebuilt. Tires: 35x14.50x16 Pitbull Mad Dogs (brand new) Frame: No clue what it's from, bought it from a JY. It's tough enough for the job and cut to fit a LongHorn bed, wheelbase and cab. All plumbing is there in stainless. Cab: 1970 Chevy Cab, no rust (new rockers, kick panels and dog legs), AC dash welded in, cab's cut for the Caddy motor and a plate welded in to support the HyrdoBoost brake system. Seats: Buddy buckets with all hardware Bed: Long Horn bed, needs assembly, includes all the supports, bedsides, head panel and tail gate. I also have a 5x10' sheet of 3/16" steel for the bed floor. Front clip: 67 fenders, radiator support and grill. Tri-Pro cowl induction hood. Extras: Custom front winch bumper, Superwinch EP16K front winch, HID headlights, 20 ton winch from a 5t mil truck with the PTO to drive it off the 203 or 205, Dual Odyssey batteries with more than 1500CCA's. I am sure I am forgetting a ton more. NO TURBO thoughts? Last edited by FormerMember; 09-17-2008 at 08:57 AM. |
09-17-2008, 10:35 AM | #2 |
Re: WIW - 1 ton c-k conversion project - a 4x4 1 ton LongHorn
09-17-2008, 10:42 AM | #3 | |
Kevin, you can't talk at all I hope you're doing better? I am just buried right now. Can't see the light of day and have too much going and with my family, this just isn't practical. |
09-17-2008, 10:47 AM | #4 |
Doing really good. Just recently purchased a house by Rollins lake. That is taking all my time right now. I'm in the process of 'thinning the herd' also. Just gonna keep my 69 GMC flatbed and convert it to 4x---------everything else is going. That is why I am towing home an 84 Blazer tonight
09-17-2008, 10:48 AM | #5 | |
Congrats on the house. I know it's tough recovering after the D. So, what do you think this thang is worth? |
09-17-2008, 10:50 AM | #6 |
Hard to say in your neck of the woods now--Do you keep receipts? or is that too scary--how much time invested?
gotta get to work now------boss just showed up-----chat at you later Last edited by kwmech; 09-17-2008 at 10:52 AM. |
09-17-2008, 10:52 AM | #7 | |
I have some of the receipts... I would be scared to add it all up. Got about 140 hours into it the way it sits. Needs another 60 or so to finish it. |
