![]() Join Date: Sep 2007
ez wiring kit
I`m going to be replacing the oe wiring from a 60 chevy 4x4 project my nephew got going with a ez wiring kit 21 cricuit. have any of you run across any issues doing this and decided on any other fuse box locations other than original.
Mods are. frame and suspension from a 78 chevytruck doner with 6 in suspension and 4" body lift, 35 inch tires, 383 stroker with 400 turbo trans I believe, 3 wire alternator and jegs hei dizzy, dash cluster from a 1 1/2 ton I believe, (it has a red axle lock light on it) will be putting on an electric fan. Oh yeah, also, have any of you guys ever put on a brake booster set up from a 73 up truck? Any tips or tricks? Thanks guys Mike ![]()
1967custom Last edited by michael bustamante; 09-17-2008 at 01:02 PM. |
Re: ez wiring kit
I mounted mine way up under the dash on my 47. The kit worked well but for some reason the brake light switch never could get a hot feed from the panel, I bougth the 21 and am still running it now. Be sure not to cut any wires you think you won't need, I am stll having to go back and add them
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
Re: ez wiring kit
re: ezwiring - the only thing I would do different is splice the wiring harness from the dash onto the end of the ez kit to make dash removal easier. The kit itself was easy as can be.
Re: ez wiring kit
thats a good idea, easy too sounds like
1967custom |
