Old 09-17-2008, 04:12 PM   #1
68Maniac
68Maniac's Avatar
Re-arching Springs?
Hello 4x4 forum, Newbie here. I am needing front 10" springs for my 69 4x4 build but can't seem to find any. Superlift has a 8" spring. One company told me that they could re-arch the 8" to a 10" spring. My question is will the springs sag over time and won't this change the spring length? Another lift company has told me I could use 73-87 springs with 1" longer shackles on my 69 swb 4x4. Any truth to this?
68Maniac is offline   Reply With Quote
Old 09-17-2008, 07:13 PM   #2
orbot
orbot's Avatar
Re: Re-arching Springs?
Ive had rearching done twice and yes, with time they loss it, they shackles would do the same in matter of time..thats my opinion
orbot is offline   Reply With Quote
Old 09-17-2008, 07:31 PM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
The newer model springs are not a bolt in, requires pretty extensive modifications, luckily the aftermarket has come to the rescue. Look up diy4x and they have a kit called b52, it allows you to use the longer springs, again, not the easiest to do. Custom springs is another answer, I recommend Alcan.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-17-2008, 08:48 PM   #4
I don`t think new springs being over-arched will sag any more than any other spring.All springs are flat steel that is arched.An aged spring will flatten over time,from factory or after re-arching.Like the springs did originally from age before they required re-arching.
I don`t see how 73-upleafs could work.The lift springs are made to end up the right length after desired arch.So,maybe,if you arched stock 73-up leafs 10" they would end up short enough to use in a pre-73.But,10" lift springs you buy are made from longer stock to end up the proper length after arching.
Old 09-18-2008, 12:05 AM   #5
Captainfab
60-66 Nut
I would suggest using a set of 52" and 56" springs for the '73-'87's in a 6" lift. Then combine these with the B52's and a rear shackle flip from diy4x.com. This should give you about 10" of lift, but of course it is a bit of work.
Old 09-18-2008, 07:14 AM   #6
10" of lift is alot of work no matter what way you go.I agree with Captainfab.That would be the way to go.I`d want longer springs for that much arch.
Old 09-18-2008, 02:34 PM   #7
68Maniac
68Maniac's Avatar
Thanks for the quick replys, I am getting a bid on the Alcan springs. But I really like the diy4x setup that you guys have spoke about and am researching it now.How tough is it moving the diy4x rear shackle eye hanger?
Old 09-18-2008, 02:43 PM   #8
68Maniac
68Maniac's Avatar
Will the truck "flex" with this setup? I am going to be running 39.5 boggers and don't want the tires getting into the body. More lift?
