Old 11-18-2002, 09:00 PM   #1
406cid70Chevy
bad voltage regulator symptoms?
What are the symtoms of an external bad voltage regulator? I'm trying to figure out what the heck is wrong with my truck. Sometimes it will just crank and crank and crank without even trying the slightest to start. And then the next time it starts right up, but then it will just suddenly die out no matter if it's idleing or in motion. I just replaced the alternator and battery. I checked all connections and wires. Could it be a bad voltage regulator? It has an HEI distributor with MSD igniton.
406cid70Chevy is offline   Reply With Quote
Old 11-18-2002, 10:52 PM   #2
Dan69 step
Sounds like an elecrical short to me. Happened on my old 60 truck, just up and died. Check the hot wire that goes down to the starter. When cold it started and ran fine. When it got warm and expanded, it lost the connection. My mechanic traced it down right away. May not be the answer, but it IS a place to start.
69 short step
68 50th Anniversary Gold/ White lwb
72 2wd Blazer
63 Studebaker Avanti
85 Avanti
66 Studebaker Cruiser
49 Studebaker pickup
3-49 Studebaker 1 1/2 truck
94 White/ GMC coe (cabin hauler)
95 chev
2015 chev Duramax 2500
Dan69 step is offline   Reply With Quote
Old 11-18-2002, 10:55 PM   #3
Dan69 step
My mistake, mine wouldn't even crank over , so the response about going to the starter was wrong. Sorry. Posted that then reread it and realized that's not it.
69 short step
72 2wd Blazer
85 Avanti
95 chev
Old 11-18-2002, 11:53 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The charging system would have nothing to do with starting.
I think you have a messed up ignition system. I'd start with dropping the MSD daeal off and trying the HEI stock and unmodified.
Old 11-19-2002, 02:17 AM   #5
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
Yea, sounds like a loose connection to the HEI and/or MSD ignition box. May also be the ignition module in the HEI, not sure if you use one with an MSD box but I have seen them do wierd things, though usually they just stop working.
Now, a bad voltage regulator isn't hard to tell at all.. you'll be driving down the road and all of a sudden your lights will get REAL bright.. and hopefully the stock fusable link will blow, unless your truck is like mine.. if so, you'll melt a whole buncha wires, and blow your battery.
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
