Old 09-17-2008, 08:47 PM   #1
matt_field
matt_field's Avatar
help bleeding hydrolic clutch
hey guys, i need help bleeding out my clutch on my 87 1 ton, i can get fluid to get to the slave and when pumping the clutch, fluid squirts out the breather for holding the fluid, do i have a bad master? hope this makes since, thanks!!
Matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 09-17-2008, 09:06 PM   #2
GM72K10
Next!
GM72K10's Avatar
Re: help bleeding hydrolic clutch
Check to make sure there's no dirt in the line, the slave cylinder's are easy to replace and not that expensive. Easier to bleed with two people. Glad my 83 is mechanical, the 88 R30 1 ton I had was like your's, couldn't bleed it either because of it sitting for so long before I got it (must of gotten rust and dirt in the line from swapping engine/trans or something) Good Luck
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 09-17-2008, 10:11 PM   #3
matt_field
matt_field's Avatar
the truck has been sitting 2 years, the only thing i thought was it was pretty much gravity bleeding it self, but when you pumped it up it was squirting back up the breather hole in the brake fluid holder. making me think the seals or somthing are bad in the master
1967 swb 2wd 427bbc
1968 4wd shortbox
