four speed?
just sort of thinking about a winter project for now.
how many of you guys have made the swap from an automatic to a standard tranny, specifically a muncie M-21 or M-22? did you need the high-hump tranny tunnel, or did it fit with the low hump? where did you purchase your transmission? ballpark, how much did it cost to make the swap? what shifter did you use (I've herd that a shifter for a 55 chevy with a bench seat works, but I can't actually remember.)
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
Re: four speed?
I've made the swap in cars. Pretty straight forward. It will fit in any spot that the 3 speed will fit, might even use the same driveshaft, depending on the transmission.
Re: four speed?
The low hump did not work for my application. Bagged w/ post 73 front crossmember. An ear of the tranny was hitting the tunnel, not by much. I made my own. I used a hurst indy shifter with a short stick, it is perfect with bucket seats. With a bench seat you would need a longer shifter w/ a bend. Also I believe there are two different mounting brackets for the Hurst shifter. One that mounts it up high, which brings it way over the tunnel and one that mounts it to the side of the tranny. I have a friend that has a 56 chevy with the low one mine has the high one so I made a console. You can get both brackets and shift sticks through summit. In the picture the top of the boot is at the top of the shifter. Its a muncie 21.
![]() Join Date: Jul 2005
Re: four speed?
I used high hump, but aMuncie m20 21 22 may fit okay under the low hump. Got my transmissions from muscle cars from the past . Saved them all these years switching from one hot rod to another. One of the members from Arizona had posted all you needed to install everything for around 1500 dollars. may have been 72 RS SS. not sure now. Not to bad of a price for a package deal. The parts I have have been aropund for a lot of years so not real sure what it would cost from scratch. But 1500 is a good price imo. But that is used parts. Good luck .Larry
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
Re: four speed?
I didnt say before but I looked around before I bought this m-21 from a friend for 500.00 w/ no bellhousing. They seem to be going for around 500-700 dollars depending on if they come with a shifter or not. Then of course you'd need flywheel, pressure plate ,clutch, bellhousing, pedals.
Re: four speed?
The car 4-speeds will fit under the low-hump.I have slipped them in and even used the same hole that was cut in the floor for a 3spd floor shifter,like the "Indy" shifter.There is a Hurst shifter made for these trucks that will clear the bench seat.
Re: four speed?
my 1967 chevy 3/4 ton truck when i got it had a 3on the tree i put in a 4 speed 4 in the floor i add the high hump i got a used four speed for $ 100 somthing or $200 somthing oh ok guys dont let any one take your four speed shifter,rod if you let me know and i give you the info how too get one
