Old 09-17-2008, 09:53 PM   #1
ashx2
Carrier Bearing Help!!
On the way home tonight, the truck started making a strange rattling noise. It sounds like it's coming from under the bed.
Could this possibly be the carrier bearing going out? It only makes the noise when traveling, not while it's sitting still idling.
Not much of a mechanic, but I'm trying. Anybody have experience w/carrier bearings going out?
Thanks,
Greg
ashx2 is offline   Reply With Quote
Old 09-17-2008, 10:41 PM   #2
7DEETWO
7DEETWO's Avatar
Re: Carrier Bearing Help!!
Sounds like it. My Center support Bearing recently broke. The same sound coming from under the bed. Don't drive it any further. Crawl under and take a look, it will be easy to see. Good luck.
Glen
7DEETWO is offline   Reply With Quote
Old 09-17-2008, 10:59 PM   #3
ashx2
If it's in good shape, it should be centered and not laying on the bottom......correct?
Greg
Old 09-17-2008, 11:06 PM   #4
jrdv
jrdv's Avatar
That is correct.
After going through 2 carrier bearings back in the 90's, I had a one piece drive shaft made and haven't had any trouble since then. Mine is a 71 short bed. I think you could have one made for about $300.
john
jrdv is offline   Reply With Quote
Old 09-18-2008, 08:16 AM   #5
MotorSeven
Restoration Desperation
MotorSeven's Avatar
New drive shaft?
Naww, just do what the P/O di on my '72 work truck.....just shoot the carrier bearing rubber boot full of silicone.
Gimmie a break........
RD
MotorSeven is offline   Reply With Quote
Old 09-18-2008, 03:50 PM   #6
ashx2
Sounds like your P/O was a real big time mechanic.......NOT!
