Old 11-18-2002, 10:38 PM   #1
kroodawg
battery relocate
anybody sell a kit to relocate the battery? I have wanted to do this but have not found a kit yet..
http://members.cox.net/ken1173/P9030017.JPG
kroodawg is offline   Reply With Quote
Old 11-18-2002, 10:50 PM   #2
crazy longhorn
Fabricate till you "puke"
i used a summit trunk mount battery kit, & built the holder tray from angle iron. My battery is mounted under the bed, on the outside of the frame rail(pass side). here is a link to the box & cable kit..... http://store.summitracing.com/partdetail.asp?part=680
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-18-2002, 10:57 PM   #3
kroodawg
Thanks crazy thats just what I was looking for.
Want to get rid of the eye sore, and clean things up a little more.
Old 11-18-2002, 11:04 PM   #4
crazy longhorn
No trouble..... It always helps to move a little weight back whenever you can. Mine has a tilt nose on it, so not much room up front. good luck.....
