09-18-2008, 09:23 AM | #1 |
rebuilding lower control arms
anyone find out where to set the inner sleeve on a 72 lower control arm, alignment shop said i had to have it close. i posted this earlier in the month with limited response. i wanted to know if someone had come across where to set the center rod between the outer caps. any help would be great. thanks.
09-19-2008, 11:37 PM | #2 |
Happy to be here
Re: rebuilding lower control arms
Anyone?
09-20-2008, 10:09 AM | #3 |
are you asking how to set Toe-In / Toe Out ?
09-20-2008, 02:09 PM | #4 |
no, on the 67-72 style lower a arms they have thread in caps on each side with a threaded center shaft, that shaft will thread in and out of the caps about 3/8 of an inch when the outer caps are seated. i know this has to throw the caster off if not done correctly, i was wondering if anyone knew a starting point to set at before i take it to the alignment shop.
09-20-2008, 04:50 PM | #5 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-20-2008 at 04:51 PM. |
09-20-2008, 11:24 PM | #6 |
1969 Short, Fleet, and Beat
We need a tutorial one this.
Anyone? |
09-20-2008, 11:35 PM | #7 |
Manual Transmission Club
If my alignment guy told me that I'd find another shop.
79 GMC Sierra Grande, SWB, Heavy Half If I wanted easy I would just buy a NEW truck! |
09-21-2008, 12:57 PM | #8 |
how bout here
Blazer Project |
09-21-2008, 06:31 PM | #9 |
ya, the part i am talking about is item number twenty five, 25, in the break down. see how the caps are threaded internally and externally. when you run the outside caps down to the arms you still have room to turn the center shaft. any help would be great. thanks again guys.
09-21-2008, 09:22 PM | #10 | |
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
09-21-2008, 09:24 PM | #11 |
I think Longhornman did a cover of this very subject Maybey someone remembers how to get it!
09-22-2008, 09:28 AM | #12 |
man it would be greatly appreciatted, like i said any info would be helpful, thanks again
