Old 09-18-2008, 12:50 PM   #1
67mater
67mater's Avatar
straightening a tailgate
anybody ever tried straightening a tailgate? I was even thingking that maybe the front skin and rear skin could be cut out, straightened and then welded back? mayeb even make a frame to keep everythign square. If I did that I would also repalce the top rolled part with new metal.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 09-18-2008, 06:16 PM   #2
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: straightening a tailgate
mine had one big dent on the edge of the GMC white part & I drilled out the spotwelds along the bottom/sides & cut the outer panel off in a flat part above the GMC. I hammered the dent flat & welded it all back together. It looks pretty good, but i should have hammered a bit more-its still has a bit of the dent... I painted the inside with zinc paint while I was there. It wasnt that hard really as many of the spotwelds were broken already...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 09-18-2008, 08:18 PM   #3
I had a badly bowed tailgate on a truck once.Now,this is serious:I took it and layed it on two 2x4s at each end with it bowing up.Then,I drove my truck over it.
I just wanted it alot straighter.Definately not a show winning truck.
Old 09-18-2008, 09:08 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
You went to A&M didn't you??
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-19-2008, 08:30 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Hey, I resemble that! Aggies improvise...
Seriously though, I tried special-K's trick on mine (slightly bowed) and it straightened it out some. Blocked the ends with the 2X4's and placed a 1X4 under it in the middle. I didn't drive the truck directly on it, I used a 2X6 as a ramp and eased up on it with one tire... A lot better than it was.
68gmsee is offline   Reply With Quote
Old 09-19-2008, 11:27 AM   #6
67mater
67mater's Avatar
excellent idea!
1967 K10
1967 Camaro
Old 09-19-2008, 11:58 AM   #7
mtdave2
newly minted old timer
mtdave2's Avatar
sounds like a good idea to me, i once straightened out my front bumper by ramming the truck into a telephone pole. little spray paint and it looked fine!
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 09-19-2008, 02:31 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
The pole?? What about the bumper??
Member Nr. 2770
Old 09-19-2008, 02:36 PM   #9
michael bustamante
michael bustamante's Avatar
Ive heard of people tack welding a bar acrsoss the inside of a bowed tailgate and clamping a winch or comealong to it and pulling it that way but I never tried that myself
1967custom
michael bustamante is offline   Reply With Quote
Old 09-19-2008, 04:01 PM   #10
SactoJim
SactoJim's Avatar
I only ordered a new one because the inside of mine was so beat up. The new (repo) one fit so crappy that I decided to cut both in half and make one good one. Where they butt together at the top, I backed it with a 2x1/4" steel strap and the bottom is just spotted together (factory).
I think one of the reasons the aftermarket gates are so weak (besides lighter gauge metal) is because they aren't spot welded together along the relief (where the handle is located and brings the front panel togerther with the inside panel). I had to make some spacers for mine, but I made sure to spot them together......just makes it stronger.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 09-20-2008, 02:17 AM   #11
R.L.
R.L.'s Avatar
The after market tailgates are weaker than the factory units? I did not know this ,who did you buy your gate from?Mines not so beat up you could not use it but its so hard to open and shut you slam it pretty hard to make it latch.
R.L. is offline   Reply With Quote
Old 09-20-2008, 05:52 AM   #12
The first repo tailgates were real weak.They`ve gotten better,but you still can`t beat OEM.Jim,that`s an excellent observation on the spots across the indent.Makes alot of sense.
I`ve bent steel by using a come-alone fastened at either end and used a block,either cinder block or large piece of wood,and drawn the metal around the block.I`m sure this could work in reverse.
Old 09-20-2008, 07:35 AM   #13
msgross
msgross's Avatar
It's not just weakness in design. I know that Dynacorn advertises that the new metal they use in their products is the same gauge as original, but has less additives allowing it to be more flexible and workable....http://www.dynacornclassicbodies.com...s/brochure.pdf
I'm gonna try to jack up my tahoe and lower it onto the tailagate and straighten it...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
