Old 05-10-2002, 05:52 PM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post Installed posi, but now have noises
I used the original shims. One of them I had to grind .005 off it on the opposite side of the ring gear. Now when I drive it there is a clicking sound inside the diff. and you can also hear a whine that sounds like a power steering pump. Any ideas. YES there is gear oil in the diff. with Limited slip additive.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
WANTED: Drop Spindles
F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 05-10-2002, 06:05 PM   #2
jmanz69
Careful, they attack...
jmanz69's Avatar
Post
You should have used a new set of shims, the whine is from the gear being out of alignment. The clicking could be from the clutches being worn. I would take it out and use a new set of shims. Just my opinion.
69 swb - in the process of being torn down and born again!
jmanz69 is offline   Reply With Quote
