Old 09-18-2008, 07:52 PM   #1
terrym5
backspace problem
Arrgh, well I did it again bought something that doesn,t fit ,so help if you know a solution bought some steel rims off a 90's chev 1/2 ton and surprise they dont fit. They are hitting the upper ball joint in the front. Thanks for you help in advance, Terry.
terrym5 is offline   Reply With Quote
Old 09-18-2008, 09:55 PM   #2
Anthony Fremont
Anthony Fremont's Avatar
Re: backspace problem
Probably the center bore is the wrong size too. I bought some billet adapters from:
Laura Dai
Instant Tools Inc.
29724 Avenida De Las Banderas
Rancho Santa Margarita, CA 92688
Tel: 949-459-9588
Fax: 949-459-9506
Model number 6550-6550BWM. They fit perfectly. I put some 16" tahoe wheels on my '66 GMC. It's hard finding six-lug adapters that have a large center bore to fit over the huge thing that GM used as a hub early on; this place was the only one I could find. I used 1.25" thick with 14mm studs for the newer wheels. Looks like this now:
$20 each including lug nuts, best deal on the planet IMO.
Ironically you could have just bought some Toyota wheels and bolted them right on.
'66 GMC Custom Fenderside LWB
'90 IROC - L98
'97 1200C Sportster
Anthony Fremont is offline   Reply With Quote
Old 09-19-2008, 11:07 AM   #3
terrym5
Thumbs up Re: backspace problem
thanks man u rock.
Old 09-19-2008, 11:36 AM   #4
Anthony Fremont
Originally Posted by terrym5 View Post
thanks man u rock.
Yeah, I know. You want the ones with a 108mm (large) center bore, that's the hard part.
'90 IROC - L98
'97 1200C Sportster
