Old 09-19-2008, 01:00 AM   #1
gottwake
gottwake's Avatar
Before I order my 4 link, I have one question.
How come I have never seen a 5 link? That is; 2 parallel bars (one on each side of the frame rail) and a pan hard? I have never seen this installation so Im sure there has to be a reason.
Im kind-of-a novice fabricator and this would be easy for me. I dont feel comfortable with the install of the triangulated 4 link. And the parallel bars looks easier to install but I will have to fab the mounts to the rear end like jlaird did to get it parallel with the ground. Anyway, any comments on the 5 link?
-Marc
Blazer Project
gottwake is offline   Reply With Quote
Old 09-19-2008, 02:39 AM   #2
leftcoast66
leftcoast66's Avatar
Re: Before I order my 4 link, I have one question.
-Marc
That's what most people do on a parallel 4 link. Its just called a parallel 4 link when you add the panhard bar also. Or they go big and install a watts link. Only downside with a panhard bar is because it is attached at one side it wants to push the axle sideways through extreme articulation. So for just 5 inches of travel, you should be fine with panhard bar and parallel 4 link, but I wouldn't go much more than that. If its set up well though, a panhard bar is a very effective way to go with a parallel 4 link. Or people go with a watts link, which attaches on both sides and has a pivot in the middle, so you don't run into the problem that the panhard bar has which is going way up, or way down it runs out of range and wants to pull or push the axle to the side.
leftcoast66 is offline   Reply With Quote
Old 09-19-2008, 08:16 AM   #3
gottwake
gottwake's Avatar
O, I was under the assumption that a parallel 4 link was only limited to the type that has the two bars vertical (one on top of another) on he outside part of the frame. But that makes sense.
Blazer Project
Old 09-21-2008, 11:55 PM   #4
leftcoast66
Yeah that's what a parallel 4 link is, and that's the part where it gets its name, but those have nothing to center the axle from moving side to side so that's where the panhard or watts link comes into play.
Old 10-06-2008, 07:37 PM   #5
Dustin07
Stirrer of the Pot
I have a parallel 4link + panhard. did you order your kit yet Marc?
Dustin07 is offline   Reply With Quote
Old 10-07-2008, 12:14 AM   #6
gottwake
gottwake's Avatar
Dustin, no I didnt yet...
Blazer Project
Old 10-21-2008, 12:33 AM   #7
ENHANCED AIR RIDE
A 5-link is 2 forward loer bars an upper frt wishbone and 2 rearward facing "lift bars" on swinging pivots. super lift capabilities and travel. Does use up quite a bit of chassis space but nice when done right.
We build links to spec if needed.
ENHANCED AIR RIDE is offline   Reply With Quote
Old 10-21-2008, 01:01 PM   #8
Dustin07
Stirrer of the Pot
that sounds like a 6 link.
Old 10-21-2008, 01:46 PM   #9
Kontrol Phreaks
Kontrol Phreaks's Avatar
You will need to sign up as a vendor before advertising product for sale.
Kontrol Phreaks is offline   Reply With Quote
Old 10-21-2008, 02:25 PM   #10
ENHANCED AIR RIDE
Yes what he said a triangulated with rear lift bars is a 6-link. a wishbone with rear bars is a 5-link
Old 10-21-2008, 03:17 PM   #11
Dustin07
Stirrer of the Pot
that would make sense.
Old 10-21-2008, 03:27 PM   #12
kizer
Its Deja Vu time again
kizer's Avatar
A lot of the Jeep guys run the Triangulated 4-link because they want max suspension travel up and down for crawling over things without worrying about the track bar binding.
Heck some even run it dual triangulated opposed to the outside bars being parallel.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 10-21-2008, 03:32 PM   #13
Longstep70
Junior Member
Not wanting to hijack the thread but does one ride or handle better than the other - triangulated 4 vs. parallel 4?
Longstep70 is offline   Reply With Quote
Old 10-21-2008, 03:41 PM   #14
hotrodhomi
hotrodhomi's Avatar
Who are you? Do you have a website?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 10-21-2008, 04:07 PM   #15
leftcoast66
It all depends on what bags you use and where you put them. Both can handle excellent and both can handle horribly if done certain ways.
Old 10-21-2008, 04:14 PM   #16
robin58
I would guess the link in his signature would be his website.
robin58 is offline   Reply With Quote
Old 10-21-2008, 04:40 PM   #17
kizer
kizer's Avatar
Clicking on his name took me here.
www.enhancedcustoms.com
I like his model.
Old 10-21-2008, 05:00 PM   #18
hotrodhomi
hotrodhomi's Avatar
I think he just added that.
'66 impala ht
Old 10-21-2008, 05:13 PM   #19
kizer
kizer's Avatar
Yeah look up above it wasn't in his sig.
Old 10-21-2008, 05:43 PM   #20
Shev
Head Peon
Shev's Avatar
Originally Posted by Kontrol Phreaks View Post
That does sound like some of the systems we make.
Later
Clint Petree
KP Components
www.kpcomponents.com
If you're gonna hock your stuff you should sign up as a vendor...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 10-21-2008, 06:28 PM   #21
Tony@AirRideTech
Junior Member
-Marc
With the exception of our S-10 setups... that is the way most of our AirBars are. They are pretty common piece.
Tony@AirRideTech is offline   Reply With Quote
Old 10-21-2008, 07:50 PM   #22
Kontrol Phreaks
- Clint -
Old 10-21-2008, 10:51 PM   #23
ENHANCED AIR RIDE
OK If any of them are done improperly, like anything else it will have less than desireable results. OK certain situations mandate a parallel 4-link, ie most newer trucks to keep gas tank in place, or at least a custom wishbone setup to retain tank. If panhard is long enough and properly mounted it will handle fine. Most consider them for racing use, but work great as long as panhard is longer for less deflection during travel. Triangulateds are a little less cumbersome if room allows. Again it depends on your goals, space, etc.
And yes my web page is in the sig, thanx for finding it.
Old 10-21-2008, 11:54 PM   #24
Dustin07
Stirrer of the Pot
Leave the pot stirring and pissing contests elsewhere. Thanks.
Old 10-22-2008, 09:57 PM   #25
61Flattop
somebody makin dumplins?
61Flattop is offline   Reply With Quote
