Old 09-19-2008, 10:10 PM   #1
krazyk88
gas tank.....
so first off I'm new to the 2nd gen c10 community. I'm sure this is on a faq somewhere, but i'm just tired of looking through tons of useless stuff.
anyway, I'm looking for an easy conversion to put the gas tank under the bed of a 69 stepside. it has the spare on the side if that makes a differance.
will something like a 3rd gen tank or a blazer/jimmy tank work?
krazyk88 is offline   Reply With Quote
Old 09-19-2008, 10:19 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: gas tank.....
Lots of info on that subject. I would stick with a 69-72 Blazer tank which is done quite a bit and probably the easiest. A 73-92 Blazer tank will fit between the frame rails but it is considerably larger and a little harder to work with...but you get about 30 gallons in it!
check these out in the FAQ section...
http://67-72chevytrucks.com/vboard/s...d.php?t=117123
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
