Old 09-20-2008, 12:01 AM   #1
69GMCLonghorn
69GMCLonghorn's Avatar
Smile GMC vs. Chevy manual transmissions
I need some advice: I just bought a Gear Vendors to "bolt up" to my SM-465 transmission... or so I thought. I dug into things and discovered that GMC did not use the SM465 transmission; they used the New Process NP435, which was, for the most part, used in Fords and a few Dodges for about 20 years. Gear Vendors had never heard of that trans being in a GM product, and therefore COULDN'T SELL ME THE CORRECT ADAPTOR. As we speak, the unit is being boxed up and being sent back.
Has anyone else but me experienced this? Or did someone Mickey Mouse my truck prior to me owning it? Any info would be great.
69GMCLonghorn is offline   Reply With Quote
Old 09-20-2008, 05:55 AM   #2
Re: GMC vs. Chevy manual transmissions
I don`t know,but I`d talk to someone else at GV.The NP435 is all over the place and was used in Chevy/GMCs for years,especially post-72.
Old 09-20-2008, 07:59 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
mine had a 435, its still in the garage.
68C15 is offline   Reply With Quote
Old 09-20-2008, 09:56 AM   #4
haysonj
haysonj's Avatar
Check their website it shows both the 435 and 465 Iwould not think it would matter what the 435 was in its still the same trans.
http://www.gearvendors.com/agmanual.html
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 09-20-2008, 11:16 AM   #5
1969 GMC
1969 GMC's Avatar
Not all GMC's had it, my '69 came with a SM465.
The NP435 was an option, just like how the Sm465 was an option...and there are 2 versions of it: a wide (creeper gear) and close (no creeper) ratio.
edit: I know it's too late now, but for id purposes, the New process tranny has an aluminum top cover...99% of SM465's have cast iron top covers. easiest way to check.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-20-2008, 12:20 PM   #6
D'Animal
Call or go to Advanced Adaptors in Paso Robles California.
They have adaptors for almost any combination you can think of.
D'Animal is offline   Reply With Quote
Old 09-20-2008, 08:53 PM   #7
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Thats interesting...that explains why the 4 speed transmission out of my Dads 70 GMC pick up has an aluminum top cover! So its a new process. Any suggestions how to get this to adapt to a NP 205? It was in a 2WD so I wonder if the mainshaft is not going to allow this?
Is this a better transmission then the SM465?
Thanks!!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 09-20-2008, 10:25 PM   #8
skchevota
skchevota's Avatar
Thanks!!
Frank
The out put shaft is diferant from the 2wd to 4x4. You would also need the tcase addapter, I would guess that that combo would be rare. Most of the 4x4 had the sm420 for the early years and then the sm465 in the later years.
skchevota is offline   Reply With Quote
Old 09-21-2008, 12:20 AM   #9
Old Chevy Mech
Keepin it runnin!
I remember my dad always bragging about his tranny being a "camper special". He loved how the 3 & 4th gear were close so he could down shift while pulling a heavy load up hill and not lose 25mph. He told me how at 250k miles he had it rebuilt and the guy said it didnt need a rebuild, but did it anyway. Its sitting in my shed. I've got a NP205 with the adapter, so it sounds like I need a different output shaft to make it work. One day i'll get a chance to play with that setup.....
Frank
1970 K-5 4X4 Blazer
Old 09-21-2008, 06:56 AM   #10
Blazer1970
Blazer1970's Avatar
Thanks!!
Frank
GM never used the NP435 in any 4WD applications. You would have to use Dodge parts to do this.
Blazer1970 is offline   Reply With Quote
Old 09-21-2008, 06:53 PM   #11
Bob B.
Correct! But be careful, some Dodge 4X4's with NP435's had divorced transfer cases.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is online now   Reply With Quote
Old 09-21-2008, 10:08 PM   #12
factorystock
factorystock's Avatar
I guess Gear Vendors does not realize GMC used different manufactures of transmissions in their vehicles, just like Ford used Warner and New Process during these years.I think they are more knowledgeable in automatics.
factorystock is offline   Reply With Quote
Old 05-03-2009, 09:23 PM   #13
1nice67chevy
1nice67chevy's Avatar
can any one help me out i have a old 4 speed tarns with the reverse all the was to the left and down what kind is it
KEEP ON TRUCKIN!!!
1nice67chevy is offline   Reply With Quote
Old 05-04-2009, 10:34 AM   #14
69GMCLonghorn
That is a Muncie SM420. It is the predecesor to the SM465, which was a little stronger. I think the SM420 had a lower granny gear, too. From what I know, it is a good tranny as long as you're not pushing a million HP through it.
