![]() Join Date: Jun 2007
72 door panels on a 71 door.....
I like the look of the 72 door panels more than the 71 door panels....
Simple swap and screw or are there size differences? Thanks in advance. |
BlahBlahBlah
Re: 72 door panels on a 71 door.....
You wont be able to crank down the window unless you get the inner window mechanisms too. The 72's stick out further to get past the plastic
Always on the hunt...
![]() Join Date: Sep 2006
Like CG already stated above on the window regs, same goes for the the door latch relays-the splined part that sticks thru the panel is longer on the 72's, also the 72 panels are held on mainly by plastic push in type clips and only one screw at the rear of the panel.
Better off with 72 doors then?
