Old 09-20-2008, 12:46 AM   #1
alskyline
alskyline's Avatar
Test Firing Engine - Vaccum Lines
I am going to test my engine in the morning and need to know what to do with the vaccum connections on the Carburetor. It is a 350 with an edelbrock carburetor. This truck goes into the body shop for Body and Paint on Monday and I need to fire the engine prior to that. No sense in major engine work or engine swap after a nice paint job. I also read a thread one time about all the things that needed to be done to test fire an engine that doesn't have the complete electrical hook-ups inside the cab. Everything is stripped down for paint. All I need is the good feeling that the engine rebuild was successful. Is there such a thing as a vaccum diagram? Thanks for your help like always.
alskyline is offline   Reply With Quote
Old 09-20-2008, 09:18 AM   #2
haysonj
haysonj's Avatar
Re: Test Firing Engine - Vaccum Lines
I would just plug all of them off you don't need any just to run the motor. You could hook up the vac advance if you want to make it idle better but really don't need it.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 09-20-2008, 09:25 AM   #3
truckdude239
truckdude239's Avatar
just plug everything but the vac advance unless you are timing it then plug it time it and plug the vac advance back in. do your 20 min cam break in ranging from 1500-2500 rpm then your good to go
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-20-2008, 09:32 AM   #4
alskyline
alskyline's Avatar
Thank You for the help.
Old 09-20-2008, 11:57 AM   #5
cdowns
cdowns's Avatar
when test firing an engine it's always smart to have a fire extinguisher handy
