Old 09-20-2008, 05:17 PM   #1
ChopperDr
Rocker progress pics
Its slow going, but one side is almost done. I have replaced corners of the floor, footwell, rear cab support, front door pillar, inner and outer rockers. I just need to hit the backside with the grinder.
Now I need to get the other side done.
Chop
ChopperDr is offline   Reply With Quote
Old 09-20-2008, 05:53 PM   #2
nhtc33d
Re: Rocker progress pics
Looking good! It must be easier having your work at eye level instead of bending over all the time. Hows the DA sander working to strip the paint?
nhtc33d is offline   Reply With Quote
Old 09-20-2008, 07:14 PM   #3
shortbed70
shortbed70's Avatar
Looks good did you use the complete outter floor pan that goes from the footwell to the back of the cab? I am needing to do the same process soon.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 09-20-2008, 07:21 PM   #4
ChopperDr
I should have bought a lift years ago. Best tool in the shop. The DA works ok. I was using it with the spindle locked to sand the plug welds down. I have been using the Norton stripping wheels a lot. They take off paint and rust pretty quick. They do generate some heat, so you need to keep them moving over large unsupported areas.
I used part of the front floor patch and a separate inner rocker. The full piece would have been easier.
Chopster
Old 09-20-2008, 10:47 PM   #5
kizer
Its Deja Vu time again
kizer's Avatar
Looks good. I'm not looking forward to tackling that myself, but its in my future as well. Must be a feature in the 60's-66's
My wife calls it the Fred Flintstone breaking system.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 09-21-2008, 12:27 AM   #6
jmedero
jmedero's Avatar
Got any more pics of the replacement in action? I am doing this now and some ref pic's would help. As always found more rust then I thought, but have never done this before.
jmedero is offline   Reply With Quote
Old 09-21-2008, 12:34 AM   #7
Captainfab
60-66 Nut
Looks good ChopperDr.....usually lots of sheetmetal to replace on these trucks. It's a good feeling when you get one side done, but then you realize you've got to do it all again on the other side.....kinda sucks sometimes.
Old 09-21-2008, 09:10 AM   #8
63sbssbbw
UCA63
63sbssbbw's Avatar
looking great Doc
I'll be there soon too
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 09-23-2008, 10:54 AM   #9
fast64chevy
X2
I am about to start on my rockers/floorpans and being new to bodywork/rustrepair I tend to overthink everything.
Jacob
fast64chevy is offline   Reply With Quote
Old 09-23-2008, 01:31 PM   #10
steverino66
X3-
Being sure about where to start drilling out spot welds is a bit intimidating to me - I don't want to make swiss cheese out of the pillars; I have the diagram showing their locations and I've knocked off the old paint, but they're not easy to see
Any tips?
steverino66 is offline   Reply With Quote
Old 10-01-2008, 06:38 PM   #11
fast64chevy
nm....and i can't delete post.
Old 10-01-2008, 07:28 PM   #12
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Awesome job!!
Did you get used "A" pillars? I built mine from 67-72 pieces which included the inner kick and "A" post little dog leg. It woked,but was a pain. You did a nice and clean job.
Alan's Classic is offline   Reply With Quote
Old 10-01-2008, 11:46 PM   #13
ChopperDr
The parts were not the 67-72 parts. I did look them over though. I guess the 60-66 parts are fairly new to the market. Even though they are made for 60-66 they required a fair bit of tweaking, but the general shape was there. My front pillars were not that bad, but why not do it right while I was in that far. I hope my repair will last 40 years like the origional did.
Chopzilla
Old 10-02-2008, 09:58 AM   #14
joesscamaro
Originally Posted by ChopperDr View Post
The parts were not the 67-72 parts. I did look them over though. I guess the 60-66 parts are fairly new to the market. Even though they are made for 60-66 they required a fair bit of tweaking, but the general shape was there. My front pillars were not that bad, but why not do it right while I was in that far. I hope my repair will last 40 years like the origional did.Chopzilla
Yep, that's the way I'm thinking. I almost get to the point of where I can say, "I've got all the pieces I need to start the floor and pillar repair", and then I look at it a little longer and see more pieces that I can replace. I'm like you...do it all while you're in there, that way you won't have to worry about it for a long time down the road. It's more work, but it'll make me feel better about my build.
joesscamaro is offline   Reply With Quote
Old 10-02-2008, 08:38 PM   #15
JoeKan
JoeKan's Avatar
Hey Chopper, you're doing exactly what I'm saving up to do. Man, I wish we were closer so I can learn as I go, but I'm prepared for the fact that I'll mess something up. I'm saving for a mig welder then I'll get the floor pans.
Thanks for the pics.
Joe
JoeKan is offline   Reply With Quote
