11-19-2002, 01:58 AM | #1 |
rear lights wont work
Im going crazy here!! My rear lights r not working at all not when u step on the break of just turn the lights on. I dissconnted the lights where they come thru the firewall and sent a shot of electricity down the wires and the lights work there so i know there is no short there or bad bulbs. And the fuse is not bad either. I dont know where the problem is.
If any u guys have any ideas or know of common problems on these trucks please let me know. Thanks |
11-19-2002, 04:08 AM | #2 |
Recovering Truck Driver
How's the firewall plug look?...might be broken wires on the other side of the plug, dirty terminals, possibly a bad switch, but that wouldn't explain the brake lights not working.....maybe even a bad cab to frame ground.....30+ year old wiring is lots of fun......
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
11-19-2002, 07:17 AM | #3 |
nah i dont think it is that cuz like when i send 12 volts directly into the wires the lights come one.
any other thoughts? |
11-19-2002, 12:12 PM | #4 |
Where's my beer?
LIGHTS
I have the same problem with the rear lights in my truck, but not with the brake lights, when I turn the parking lights on, the rear lights work, but when I turn the headlights on, the taillights go off, I messed with the switch and found out that if I push it back in just a bit the rear lights come back on, sooo I suspect a bad switch in my truck, did you replace yours yet?
Paul How do you make the invisible, visible?.........You take it away. |
11-20-2002, 02:30 AM | #5 |
I got it fixed, kinda. I cleaned allll the contacts in my fues boz and got a new flasher. It all works now but when i turn on the pass. side turn light the right read break light goes out, but i am pretty sure that is a simple ground problem. But also now my dash lights all went out. I ran out of day light to get that done today so i will get on that one tomorrow.
11-21-2002, 12:46 AM | #6 |
its all about the +6 inches
The turn signal problem you describe now is common.
The turn signal switch needs replaced. |
