Old 09-20-2008, 07:21 PM   #1
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Stumped, need help!
Last week I was driving the 68 when it died like it had run out of gas although the tank read 1/4 full. I thought the gauge had gone out, so I got a gas can and put in a few gallons with no difference. It idles ok, but cuts out and dies.
Pulled the sender and pickup to check for a clog, found none. Blew out all the lines, put in an inline filter and a new fuel pump. No change. It idles fine, runs OK until about 30 mph and it will cut in and out and die.
Rebuilt the carb and put in a HEI distributor I had for it. Still have the same problem.
Any ideas?
low'n slow is offline   Reply With Quote
Old 09-20-2008, 07:40 PM   #2
67dragtruck
67dragtruck's Avatar
Re: Stumped, need help!
Wow. It sounds like you had it covered. That's rough. I'll give it some more thought.
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 09-20-2008, 07:54 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Could be electrical. You might check the wires bolted to the little stud on the right fender. The 30 mile per hour thing could be coincidental. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-20-2008, 07:59 PM   #4
low'n slow
low'n slow's Avatar
I was thinking of tracing out the wiring under the dash, on the fender, etc. I will let you know..
Old 09-20-2008, 08:12 PM   #5
uno67
uno67's Avatar
i had they same problem. i had never replaced the fuel hose from the tank to the steel lines. they were old an cracked and ballooned. so it would idle fine but when i would get to driving it with the more demand for fuel it would suck air in and shut off. wait a little bit it would start back up and run fine after the air bleed out of the line and filled back up with fuel. so i would check the hoses see if thats the problem.
uno67 is offline   Reply With Quote
Old 09-20-2008, 09:02 PM   #6
low'n slow
low'n slow's Avatar
The wires bolted to the stud are tight, I've run the motor and wiggled all the wires to no avail. The thing that puzzles me is the sudden onset of the problem.
It is a 6 cylinder with a floor mounted 3 speed.
Old 09-20-2008, 10:06 PM   #7
skchevota
skchevota's Avatar
Sounds like fuel, Check the gas cap vent.
Also, I would install a test guage to make sure you have fuel pressure when it stalls. If it does, i would open up the carb and see if it is gummed up.
Also check for possibe water in fuel.
Did you run a wire from the fuse box to your HEI.
The original ignition wire for the points is a resistor wire and wont supply the HEI with 12 volts.
skchevota is offline   Reply With Quote
Old 09-20-2008, 10:10 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The gas tank may not be venting well. Pull the cap and check to see if it will go over thirty.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-20-2008, 10:11 PM   #9
skchevota
skchevota's Avatar
Opps, I just re read your post and see that you already rebuilt the carb. But I would still check the fuel pressure and take a sample of fuel in a jare to check for water. If all that is good, Hook a volt meter up to your hei power lead at the distributor and then take it for a drive, if you have power when it stalls, you will know it is not in your wiring.
You might want to check your engine to frame/body grounds as well.
Old 09-22-2008, 09:40 PM   #10
low'n slow
low'n slow's Avatar
I connected the distributor directly to the battery and it still stalls and stutters. That eliminates a wiring problem. When it stalled, I popped the hood and glanced at the fuel filter, it had fuel in it. I've checked and rechecked the fuel lines, thay are clear and the rubber ones are in good shape. So, I'm back to the carb. I'll pull it apart again and blow out all the little holes and stuff.
Old 09-22-2008, 10:32 PM   #11
jholley
jholley's Avatar
Two thoughts on your problem. Either the fuel tank is not vented and it's creating a vacuum lock or maybe your exhaust is too close to the fuel line and you are getting a vapor lock.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 09-22-2008, 10:54 PM   #12
skchevota
skchevota's Avatar
Speaking of exhaust, any chance something is blocking ot up? crushed pipe,muffler gon bad, disgruntled neighbor with a potato???
Old 09-22-2008, 10:55 PM   #13
texastrendz
sounds like it is pulling a vacuum for sure, check take vent. after it stalls pull your gas cap and see if has pulled a vacuum. you will here a sucking noise as soon as you pull it. just a thought
texastrendz is offline   Reply With Quote
Old 09-22-2008, 11:12 PM   #14
low'n slow
low'n slow's Avatar
I will try the gas cap, but why would it all of the sudden do that? I have been driving the truck for 6 months. Do gas caps go bad?
Old 09-22-2008, 11:33 PM   #15
72BLUZ
72BLUZ's Avatar
any thing vented can become clogged at any giving time. the next thing i would check would be the plugs and wires. they can cause this problem as well as the other items that have aready been posted. check your battery votage as well as your alternator. low voltage can cause poor acceleration.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
