Old 09-21-2008, 01:26 AM   #1
chev-obsession
chev-obsession's Avatar
4 speed transmition gears
does anyone know what gears were in the 4-speed manual transmition? also what gears were in 6 cylinder trucks? and what is the top speed capabilities?
chev-obsession is offline   Reply With Quote
Old 09-21-2008, 06:47 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 4 speed transmition gears
You can have a couple different rear gears,usually a 3:73 or a 4:11.There are others possible.You can look on the housing and find the code,someone should be able to decode it for you.It may also be on the SPID on the inside of the glovebox.This is assuming no one has changed them.(the truck is 40 years old)I don't know tranny gears but they are pretty low(I don't have my book handy or I would try to look them up).The 6 can be a 292 or a 250 unless it's a GMC V-6.You need to really give more info on the truck for better info.
Top speed is probably about 85-90 but I doubt you want to run it that fast .One thing to remember is that newer vehicles with OD run lower RPM's than the old trucks because of the OD.You will think it is revving way too high because of this.Tire size can make some difference.
What are you wanting to do? If your goal is hiway cruising you can do some things to help without breaking the budget.Let us know more about the truck and your goals and we can give better suggestions.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-21-2008, 08:14 AM   #3
Ace in the hole
if it's the sm465 the gears are:
1st- 6.55 to 1
2nd- 3.58 to 1
3rd- 1.7 to 1
4th- 1 to 1
reverse 6.09 to 1
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 09-22-2008, 04:11 PM   #4
chev-obsession
ok, i will check the code. do you know were it is located? and no it doesnt say what it is in the glovebox, and the vin number matches so nobody has changed it. i want to put a posi in the truck, but i like the gears that are in it, but i am not sure what i have.
Old 09-22-2008, 04:53 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Are you wanting to know what rear gear ratio is usually in a truck with a 4 speed or were you asking what gears are in the actual transmission?
If your asking about the rear axle gears, it varies.
A very simple approach to determine your axle's gear ratio is to mark a chalk line on a tire and the driveshaft and then have someone move the vehicle forward slowly as you count how many driveshaft revolutions there are to one tire revolution.
Just over 3 driveshaft revolutions to 1 tire revolution = 3.08 gears
About 3 3/4 revolutions = 3.73 gears
Just over 4 revolutions = 4.10/4.11 gears
Just over 4 1/2 revolutions = 4.56 gears
etc.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-22-2008, 08:34 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
and rear gear options/base gear aren't the same for a 1/2 ton and 3/4 ton.
And as far as top end.... all 1/2 tons should be able to hit 100 MPH and still have room to go before hitting the redline, and the same for MOST 3/4 ton trucks.
Old 09-22-2008, 11:27 PM   #7
chev-obsession
ok thanks. this is what i wanted to know.
