4 Speed Transmission lenghts
My trany recently decided to blow up on me. It was a non rebuild saginaw. Now my question is if i wanted to change it over to say a muncie or supper t10 is there a diference in lenght? Will i have to build yet another drive shaft. I no on some of them they have the diferent input and output shafts Is that true? Thanks
Re: 4 Speed Transmission lenghts
I can't say for sure about all the different trans. but I replaced my three on the tree with a sm465 four speed and did not have any problems. Mine is 4wd and I had to get a different adapter to mate it to my transfer case but other than that it bolted right in with no drive shaft mods.
I do know that the sm465 came with several different output shafts. The 4wd had 10 spline output and the 2wd had 35 (?) spline output. The inputs were the same though I think. The truck version is basically a three speed, first is a creeper gear and never used unless your towing big weight. Some more info on them- http://www.novak-adapt.com/knowledge/sm465.htm
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
You are wanting to put a car 4 speed in correct? If so it is a direct bolt in in place of the three speed (on column) pull 4 bolts and replace. I ran a m21 in my first truck for several years. Just be sure you dont get a vega trans (saginaw) as it will not hold up.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
