rear end help
ok 67 chevy step side blown rear end it is going to get a 350 not to beefed up but i need a rear end that can handel the power of a 350 and not snap but i still want to role down the highway what should i go with???????????
thanks nate ![]()
nate ![]() |
Re: rear end help
Rear ends don't generally break under stock horsepower You just need to change the gears to match the use of the truck.
69 Chevy 4x4 383 Power ![]() |
Thread Killer!
Re: rear end help
Is it a regular 12 bolt?
If so it should handle any abuse a 350 can dish out. As for rebuilding get a set of gears, a quality posi unit, ( i bought an Eaton) and a master rebuild kit and put it together or pay someone to set the gears up for you. You should be able to buy all that and pay for setup for around $800 to $1000. Check the axel bearings while you are there also.
71 Cheyenne SWB LS1 and auto. http://67-72chevytrucks.com/vboard/s...d.php?t=256470 _____________________________________ If it's worth doing, it's worth doing twice... _____________________________________ Don't Mistake Honesty for Negativity... |
![]() Join Date: Jan 2008
Re: rear end help
I built mine up with Moser axles, Eaton posi, Richmond 4.10s and a good rebuild kit. thats pretty much bullet proof even on slicks
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
its all about the +6 inches
Re: rear end help
the same rears were used regardles of inline, V-6, small block, or big block... it'll handle a 350. I've seen stock peg leg 12 bolts hold up to a LWB truck in the high 12's in the quarter.
![]() Join Date: Jul 2005
Re: rear end help
Here is an article tht compares some rears to another. There is discussion for the 12 bolt rear ends and sort of a history too. May help to answer a question for you. Have fun.http://www.carcraft.com/techarticles...ord/index.html
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
