Old 09-21-2008, 11:56 PM   #1
drivethechevy
drivethechevy's Avatar
mystery screw
the doors on my 68 k10 were orignaly off of a 69-72 suburban judging by the trim and back corner swap and there is a screw and indent under the wing windows that i have never seen before
what was the screw and indent for? is it a suburban only thing? is it a year specific thing?
here is a pic of it
thanks
nate
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 09-22-2008, 12:27 AM   #2
Mint68
Mint68's Avatar
Re: mystery screw
A screw like that is a 1972 only thing. Blazers had them, but with a black plug and screw with a bigger hole. The 72 trucks had just the screw with the indent. The doors should be 1972 only. I guess the doors could crack along the top edge???, so it was added to stiffin or make the door more ridgid. Hope my info is correct/helpfull.
Mint68 is offline   Reply With Quote
Old 09-22-2008, 12:29 AM   #3
Mint68
Mint68's Avatar
Re: mystery screw
Forgot... I also think that 1972 doors can only use the 1972 door panels. May want to check into this. I'm not 100% sure, I've never had a 1972. Someone will chime in.
Old 09-22-2008, 01:01 AM   #4
fine69
fine69's Avatar
Re: mystery screw
Doors would crack near the wing. Thats why the screw was added.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 09-22-2008, 10:47 AM   #5
Luvlegs
Luvlegs's Avatar
Re: mystery screw
if you want to use different panels on the '72 doors, you have to change the window regulators for the shorter shafts (previous years) -I'm not sure about the door handles.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 09-22-2008, 03:01 PM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: mystery screw
My 71 doors have that
but not on my 69
LOW DOUGH is offline   Reply With Quote
Old 09-22-2008, 07:41 PM   #7
sweet70beast
sweet70beast's Avatar
Re: mystery screw
My 71 doesn't but all three of my 72's did including my Suburban.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 09-22-2008, 07:55 PM   #8
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: mystery screw
They '72 doors don't have the threaded inserts to mount the 71 - down style door panels either. I can tell by the big holes in your's that it will not accept the older door panels. You'll need '72 model platic door panels.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 09-23-2008, 09:26 AM   #9
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: mystery screw
Makes me want to go look at the doors but they are in terrell. 45 min away. I remember taking that screw out once to take the big glass out. PO's must have put 72 doors on it. Huu learn something everyday.
Old 09-23-2008, 09:27 AM   #10
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: mystery screw
Makes me want to check the VIN again. I know it's a 71 VIN.........
I will have to look at lunch. I have the 69 doors on it right now so i couldn't see what we are talking about.
