#1 | |
Bloo
will this work? (trans/tcase)
as can be seen in my sig, im planning to turn my wrecker into a K30. this thing is so heavy i cant park it on dirt for more than a week, without having to pull it out with something else because it gets buried so deep by sinking.
anyways, i have to have a driver side output t-case, as my winch PTO is on the passanger side. i have a 80s 32 spline SM465 hooked to a NP208 i plan to put in. i took a jeep driver drop 208, and installed the chevy 32 spline input shaft into it. i then hooked it up to my chevy trans, but im afraid the transfer case is angled to bad to oil correctly. please see the pics and tell me what you think thanks! Josh
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
![]() Join Date: May 2007
Re: will this work? (trans/tcase)
Just my opinion, it would be easier to relocate the pto to the driver side.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
That will work fine... usually the rock crawler guys go the other way with clocking them.
The chain works really well as an oil pump ![]() Although with all that work, why not an NP205 and run the PTO off of it? Last edited by FormerMember; 09-22-2008 at 07:05 AM. |
#4 | |
Bloo
i know the NP205 would be stronger, but i have a total of $57 in that set up as you see it, including both shifters. i still need a couple peices, but it should come in under $100 for my entire trans/tcase set up
i know it sounds crazy, but i'd much rather mess with the transfer case and mounting an axle, than modifying anything on the bed and winch set up. its all set up for a passanger side PTO and all the controls work so im afraid to touch them ![]() here is the victim:
#5 | |
How many miles on the 208? GM put those t-cases in 1 and1/4 ton trucks (CUCV), so you should be ok, theoretically. I do know people blowing them out. So, I ask if you're going to replace the chain, as it stretched with allot of miles and will wear the bottom of the case, causing it to crack eventually. One of the reasons I went with a 203/205 doubler was to have a PTO option on both sides ![]() |
![]() Join Date: Mar 2003
If you want to spend some money, I have an NV4500,203 chevy and a 205 ford already set up for a wrecker. It is complete with a pto unit built special for the 4500 on the pass side.
Post Whore
![]() Join Date: Feb 2000
Gonna be the baddest wrecker around when you get it on the road!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I have a left hand drop NP241 if that helps
#9 | |
Bloo
man yall are killing me
![]() grendal, im not really sure on the miles, but i was told it was under 100,000 when it was given to me. i had the trans guy at work watch me put it together and he said the chain had to be a new one with how tight it is. kwmech, i would LOVE to have a 4500 setup, but thats defintly out of my price range based on what ive seen 4500s sell for special, i had actually hoped to find a 241, but wound up getting the 208 for free so i rigged up this set up. based on the 241 in my 89, those suckers can take a beating... mine has 252K miles on it with no problems. im defintly intrigued
