05-10-2002, 06:58 PM | #1 |
Got 20's????
re-angle axle after flip kit?
Should I get the new angle spacers for my truck after doing a flip kit? My diff points up a bit and my driveshaft is really close to the cross member if I go over bumps.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota WANTED: Drop Spindles F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
05-10-2002, 07:40 PM | #2 |
Yes you will prob want to use a shim kit to maintain the proper pinion angle. If you can't find one for a 72 a later model should work w/only minor mods.
